DK4510 2485 Backhoe Lacking power
/ DK4510 2485 Backhoe Lacking power #1
Grant1
Middleburg Fl
Kioti CK30, Kioti DK45hst
I have a DK4510 with a 2485 backhoe attached which seems to lack power on breakout force. I have also owned a ck30 with a 2375 that actually seemed to have more power with the backhoe. I really noticed this yesterday trying to remove palmettos running at 1800 rpms. . I also could not pick up the corner of a 4" concrete slab driveway. The backhoe digs dirt fine but really seems to lack the power on other uses. Thanks in advance for any advice
/ DK4510 2485 Backhoe Lacking power #2
If your loader works fine, I would assume the tractor hydraulics and its pressure relief valve are set right. The bh itself does have its own pressure relief valve. You'd have to attach a gauge to a hyd line, like the dipper or bucket curl cylinder on the bh, and see what you get.
/ DK4510 2485 Backhoe Lacking power #3
I have a similar issue. Had a CK 25 w/2475 backhoe. It seemed to work fine. In 2012, I traded for a DK 40SE w/cab and a 2485 Backhoe. I find that the boom seems "weaker" than the smaller hoe was. I had the dealer come out and he put a guage on the cylinder. Pressure was almost 3,000 lb, so we put the return line directly into the filler tube. (there's a kit for that) It is better, but it's still just doesn't "feel" right.
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Hydraulic Pump (A65640)
Hydraulic Pump...
2007 International 7300 Digger Derrick Crane Truck, VIN # 1HTWBAAN77J422035 (A65563)
2007 International...
Pull Behind Sprayer (A65640)
Pull Behind...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
