wiring toggle switch
/ wiring toggle switch #1
musselmark
grand tracadie PE
'05 NH TN75DA
Not tractor related but I have a little 50 Giovanni quad and it has a 4 pin 2 position key switch, we lost the keys and I want to replace it with a simple toggle switch. There are 4 wires, one key position completes 2 wires (black and red) and leaves other 2 ( green and black/white) open, other position does the opposite, completes green and white/black) and leaves red and black open. What kind of switch do i need, I am thinking a triple throw double pole 6 pin (on off on) and only using 4 of the pins. Is there any type of simple toggle with just 2 positions that could do this?
/ wiring toggle switch #2
With a toggle switch you will still need a momentary switch for the starter.
I would just replace the switch.
Thanks gyus, I ended up using a dpdt 2 position (on-off) switch. center right and upper right for one pair and center left and lower left for other pair.
/ wiring toggle switch #6
Looks like you got it. DPDT was what I was going to say but you figured it out. Just out of curiosity, what are the two wires that close when the switch is off?
/ wiring toggle switch #7
Probably an anti theft device. Shorts out the ignition so it can't be hot wired...
John Deere 6400 (A64126)
John Deere 6400...
2022 EZ-GO ELITE...
UNUSED SDLANCH HIGH END 5M RATCHET STRAP SET (A64280)
UNUSED SDLANCH...
APPROX (50) 2" X 2" X 22" TUBING (18) 2" X 6" X 51 (A64280)
APPROX (50) 2" X...
UNUSED AGT MX-MRT14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
2015 John Deere 319DT Skid Steer w/ Bucket (A63688)
2015 John Deere...
