wiring toggle switch
/ wiring toggle switch #1
musselmark
grand tracadie PE
'05 NH TN75DA
Not tractor related but I have a little 50 Giovanni quad and it has a 4 pin 2 position key switch, we lost the keys and I want to replace it with a simple toggle switch. There are 4 wires, one key position completes 2 wires (black and red) and leaves other 2 ( green and black/white) open, other position does the opposite, completes green and white/black) and leaves red and black open. What kind of switch do i need, I am thinking a triple throw double pole 6 pin (on off on) and only using 4 of the pins. Is there any type of simple toggle with just 2 positions that could do this?
/ wiring toggle switch #2
With a toggle switch you will still need a momentary switch for the starter.
I would just replace the switch.
Thanks gyus, I ended up using a dpdt 2 position (on-off) switch. center right and upper right for one pair and center left and lower left for other pair.
/ wiring toggle switch #6
Looks like you got it. DPDT was what I was going to say but you figured it out. Just out of curiosity, what are the two wires that close when the switch is off?
/ wiring toggle switch #7
Probably an anti theft device. Shorts out the ignition so it can't be hot wired...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
John Deere Worksite Pro RS72 (A64119)
John Deere...
2009 JARRAFF GEO BOY LINE BACKER BRUSH CUTTER (A64279)
2009 JARRAFF GEO...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
UNUSED SWICT 72" BUCKET (A64280)
UNUSED SWICT 72"...
