Trailer storage
/ Trailer storage #1
blumbergh
St. Louis,Mo
none
Hello everyone,
This is my first post and I am looking forward to some thoughts on this.
I am thinking of selling the truck and getting an SUV. I have a long commute and the truck just isn't cutting it in the comfort department. That being said I still need to haul stuff and my ATV around so I was going to buy a trailer as well. My problem is I have no place to put it. I have a two car garage that my wife and my Nova use so I am a bit stuck.
Then my wife says to me why not just store the trailer in the garage with the nova on it?
I wasn't planning on getting a trailer that big but I thought it was a heck of an idea. I realize if the car is on it for a long period of time the tires may get flat spots but I was thinking that a few jack stands and some 4x4's could help out with that.
Anyway what are some thoughts good or bad about this idea. Some things to look out for etc.
thanks everyone.
/ Trailer storage #2
Hello everyone, This is my first post and I am looking forward to some thoughts on this. I am thinking of selling the truck and getting an SUV. I have a long commute and the truck just isn't cutting it in the comfort department. That being said I still need to haul stuff and my ATV around so I was going to buy a trailer as well. My problem is I have no place to put it. I have a two car garage that my wife and my Nova use so I am a bit stuck. Then my wife says to me why not just store the trailer in the garage with the nova on it? I wasn't planning on getting a trailer that big but I thought it was a heck of an idea. I realize if the car is on it for a long period of time the tires may get flat spots but I was thinking that a few jack stands and some 4x4's could help out with that. Anyway what are some thoughts good or bad about this idea. Some things to look out for etc. thanks everyone.
I did that. No different then say a boat trailer storing a boat. Let's be honest, boats sit on the trailer 99% of the time. Same with a camper or lots of other stuff.
Your issue is garage size. For a Nova you will need a 7K 18' trailer at a minimum. With the trailer tongue you are looking at 22' depth minimum. Most garages are not this deep from back wall to garage doors.
I would on do this with radial tires on the trailer and if sitting more than a month do as you say and put it on stands from the axles, not the frame. This keeps the load distribution as it should be.
Chris
/ Trailer storage #3
Does the trailer have to be garage kept? Do you have any other space on your lot that you could pigeon hole one? If buying new, I could understand wanting to protect it, but a lot of trailers are stored outdoors.
I bought a used trailer when I bought my first tractor and it has lived outdoors for 4 or 5 years now and before I owned it, there's no telling how many years it had already been stored outdoors.
Most trailers have pressure treated wood on them and it lasts a long time, but when spent, can be replaced.
Another alternative is to build a shed roof off one side of your garage to park the trailer under if you have enough room to do this.
I have a shed roof off the back of my garage and while I have parked the trailer under it a time or two, I rarely do because it's an odd spot to hook up to and park back into, so I usually park it beside the garage (completely exposed to elements) or I have another spot I tuck it into the woods out back that is easy enough to access when I need it, but quite out of the way for everything else.
/ Trailer storage
The nova is a 65 so it is a bit short. Just over 13 feet. It's no 68. I believe the garage is just over 18 ft as I can fit my crew cab Silverado in it if I really need to. If I could find a 12-14' trailer and add about 3' for the neck I think I could just make it.
/ Trailer storage #5
Hi. Welcome.
As diamondpilot mentioned. My garage is standard two car and is 20ft 3" deep. Leaving two feet to walk around and clear the door that leaves a trailer with 18ft max length. A folding tongue trail will help but most trailer have four to five feet of tongue length. This leaves about 14ft of trailer length to work with.
You did not mention if the Nova gets driven. Driving it on and off the trailer will give a new set of challenges. you would have to back the trailer in and block it up all the way around and chock the tires to keep it in place while loading and unloading.
Storing the trailer outside is a possibility. I store a utility trailer outside year round. I park it on wood planks to keep the tires off the ground and cover it with a tarp to keep the sun and other stuff off it. After six years it still looks new and no problems with the tires.
/ Trailer storage
Well it looks like overall length will be tight but sacrifices must be made for the sake of my toys.
/ Trailer storage #7
Welcome to TBN....................
Storing the Nova on the trailer is ok if you have a deep enough garage to account for the extra length of the tongue (as mentioned). Also, important, is the garage door opening high enough to back the trailer in the garage with the Nova on top of it.
/ Trailer storage
The height should not be a problem. I think they are 10 ft in the garage.
/ Trailer storage #9
If you have outdoor off street parking, buy an enclosed car trailer to store the Nova, then the SUV can be in your garage too.
/ Trailer storage #10
I would think if your main load will be the ATV a 5ft x 8ft trailer (2000lb gross) would work. The one I have has a break neck tongue. with the ramp folded in it is only 18 inches high and weight about 300lbs. I have see them suspended from the ceiling with pulleys. Four pulleys on a hand wench pulls it up above head height.
Possibilities are endless.
/ Trailer storage
I need something a bit bigger than that. I am building a hunting cabin and deck so I will be hauling a bit of lumber as well.
Good idea though.
/ Trailer storage #12
Here's the winning idea. That's what I have. Wish I'd thought of and posted it. My enclosed trailer is 24' inside so I have my Polaris ATV, JD riding mower, and 79 Vette stored in mine. My garage has a Camaro, 49 Chevy 1 1/2T truck, and my LS tractor. I need more garage space. Gotta sell some things this spring to cut back on the toys.
/ Trailer storage #13
You need a trailer long enough to balance the load. A 13' car will not fit on a 14' trailer.
With only 18' of garage I think this dream is fading fast!
Chris
/ Trailer storage #14
If you have 10' I would buy a lift, about $1800, then store the trailer on it up in the air. My uncle does this with his trailer and a Corvette. Best thing is you end up with another toy!
Chris
/ Trailer storage #15
A 16foot car hauler should suffice. Don't NEED an 18 footer, unless you WANT one.
/ Trailer storage #17
Maybe you can have too many toys.
Bruce
/ Trailer storage #19
My trailer is stored outside without any problems. I could make room for it inside, but like you I have more important things to store inside.
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
