Updated Chainsaw Mounts
   / Updated Chainsaw Mounts #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I carry my chainsaws on the engine cover, and had installed aluminum guards to hold them in place. The handles had been held down by two aluminum guards and then a long bolt with a wingnut went thru the guards and across the handles. But they constantly disappeared, vibrating loose and then the chainsaw would end up on the ground.
So I went on CL and found some hood straps to a Yamaha snowmobile that looked like a good find. Went to the hardware store and got a clothes hook..
   / Updated Chainsaw Mounts #4
I might just borrow that idea!
Has the added benefit of getting a good coating of bar oil on the hood for added rust protection. :D
   / Updated Chainsaw Mounts #6
Rust will never ever be an issue on my PT.
Mine was actually squeaking this morning! Haven't driven it in a month. No grass to mow and no snow to plow till this morning. Gave the ball joints a good soaking of Teflon lubricant and it quieted right down.
I've thought about putting my saw on my PT for trips into the woods, but I seem to rip everything off the tractor that gets mounted to it. Lights, fire extinguishers, heck, I've even ripped off half a dozen lynch pins from the rear pin hitch and the brush cutter front wheel posts just from backing through tough brush. I'm almost to the point of swapping the pins for bolts and lock nuts.
   / Updated Chainsaw Mounts #7
Why not add a pin holder somewhere protected, like on the tunnel? That way the pin is handy when you need it, and out of the way of evil brush snatchers. (I leave mine on the shop wall until I need it.)
Love the mounts. It gave me ideas for all sorts of mounts.
All the best,
Peter
So, my mounts are pretty cheese wiz. And there is a downside. If you are a frequent visitor of your engine, you will find it a PITA to constantly remove the chainsaw to get to the engine. Also, I used Aluminum to keep it all light as possible.
   / Updated Chainsaw Mounts #9
All the best,
Peter
For the rear pin hitch, yes, that would work. For the ones holding the wheel's on, I was kinda surprised how many I've lost so far. I carry a bag of them in the toolbox on the trailer.
   / Updated Chainsaw Mounts #10
Why would you have to remove the saws? Looks like they're on the top and would tilt with the lid.
1983 Case 580D (A47477)
1983 Case 580D...
2025 60in Forks and Frame Skid Steer Attachment (A55787)
2025 60in Forks...
Giyi Telescopic Boom (A53316)
Giyi Telescopic...
2016 Kenworth K370 30FT Box Truck (A55788)
2016 Kenworth K370...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
Gehl 2580 Round Baler (A50775)
Gehl 2580 Round...
