reeltime
- Joined
- Dec 29, 2009
- Messages
- 187
- Location
- East Freetown ma
- Tractor
- 2014 mahindra 3016 shuttle loader and backhoe with thumb
I have a 3016 with backhoe if I remove backhoe I can use the backhoe lines for the splitter right
But I could use the lines for the backhoe right because I still have that splitter
Sent from my iPhone using TractorByNet
When I remove the backhoe to put on the splitter, I use the rear remotes. The next time I split I will try the backhoe connections. As far as speed goes....I never have to wait with the Split Fire as it splits both ways. (Don't have to wait for the blade to return)
get the 4 way, and log lift it's an awesome table. you can easily fit 16" pieces next to one another on the table. if you cut to longer that 16" consider one of the larger lengths. the 24" is like 32.5-33" between the uprights so you can just barely fit 2 16" pieces on the splitter at the same time. If I could do it again I would go with a 28" model.How do you like it... would you buy it again if you had it to do over?
Considering one for the L3800
I believe my tractors max flow is 17.1 GPM at ~2700 rpm
I sent an e-mail for more information...
This way my splitter can stay home and my
Can the 3 point be lowered to the ground to avoid extra lifting?
