Tires Anyone here using chains on there B series industrial tires? Either winter or summer?
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #1
Notomo
Cotton, MN
B2320
Have a lot of ice under the snow and getting annoyed spinning and back end sliding sideways so I am thinking about chains for my B2320 but Considering chains are at least 200 for a set I am wondering if anyone here uses them in the summer to help in mud, not sure they would make much of a difference but dunno every bit helps in some of the crap around here. Thinking I may spend a bit more for a bigger diameter set to get better traction for summer use as well. Usually the Industrials are ok but I have had her bellied out 3 times and had them clogged up good got it out without needing a tow or winch but dunno almost think she would have gotten out a bit better with a bit more tread on the tires 2 of the times I had to use the loader to get some brush under the front tires and push some in around the backs as well.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #2
My B2620 has 2 link ladder chains on R4 Industrial tires that were bought for snow/ice. They work in dirt e.g. tilling and general yard chores without much lawn damage before the snow actually comes. As to belly out in mud I can't say.
Cheers to the Vikings,
Mike
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #3
R4's and mud do not mix......
I used 2 link ladder chains like oldballs on my Kubota L4400 with R4s. I used them during Winter and Wet Spring in the timber. Made a huge difference. I also had a set for my B2910 with R4s. Same uses.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #4
I have a set of ladder link chains for my B7500 that I got from Peerless Chain. I have only had to use them a couple of times, but they definitely make a BIG difference on ice.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #5
I now have front & rear chains for my L3200. Unfortunately I can't use the chains on the rears, as my R4's don't have enough clearance between the tire & fender. Make sure you check that before you get some chains, proably need at least 2" of clearance at the narrowest spot to avoid chewing things up. I may or may not ever get wheel spacers to permit rear chains. After recently acquiring the front chains they have been good on their own.
R1s probably have less clearance issues & more mounting options to make that less of an issue.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #6
Do chains do any good on R1s. Unless you get radial chains wouldn't they just fall between the lugs?
Ya originally I was going to get the tractor with ag tires but they were special order and would have had to wait longer and the guy swore by the R4's because on the hard surfaces they don't beat you up as much and last longer yet still give good traction. For the most part they do a good job just when ya get in the really sloppy crap you start having issues, that being said I have other equipment stuck way worse than the B2320 and it got itself out all 3 times, which impressed me greatly. The one time I was sinking a foot in the mud that it was bellied in rolled a cut off stump under the loader lifted up the front end stuck some log pieces under the front tires and I think I dug out behind the rears a bit, and it drove itself right out.
They have a few different options to have them not fall between the lugs here are a bunch of pics of diff styles 12-16.5 Tractor Tire Chain the duo and euro ones might/should work. I definitely intend to measure my clearances before I order or pick up chains I am just in the research phase still, I am leaning toward the duo-grip style to help with side to side slipping. I called and my local fleet supply carries some chains in my tire size but will have to take a look at them would be nice if they were a decent set save about $100 on shipping.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #8
I just received my Duo chains from Chains.com in Johnstown Pa and ordered factory 1 1/5 spacers for my B3300SU. Had a logger in and I have a pig-pen of slop, even with 4X4 low, it just slips and slides like ice! Total bill to go play in the mud around $600............................but oh what fun!
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #9
I had chains, front & rear on a Kubota B7100 HST with turfs. Did wonders on ice/snow and in mud. The front chains really helped a lot. Chewed through frozen crusted snow and pulled in the direction they were pointed. Summer time really increased pulling ability and use in mud.
The rears were originally four link V bars but very rough ride. Added angled cross link between the ladders. Made for much smother ride.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #10
I bought duo-grip rear chains and ladder front chains for my B2920 with R4 tires. Where I live snow is often preceded by rain and/or sleet, over mud. Without the chains my tractor was almost helpless when I tried to use my rear mounted snow blower. I don't have front weights (yet), and steering was almost impossible without the front chains. The duo-grip give a rough ride but I'll accept that for the traction. I have spacers on my rear wheels, but I'm not certain they are needed.
Pat
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #11
I did forget to mention that I have R1 (loaded) w/ a backhoe on and still slid every place. I opted not to do the V bar and chose Dou for ride and lawn issues. After reading several posts on here and speaking to the dealer, front chains where NOT recommended for my B3300SU. But we will see after I get the spacers and chains on. By that time things may be froze enough to not need anything till spring.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #12
I have used HD ladder type chains on my B1750HST for over 20 years when plowing snow. As originally equipped, my tractor has front turf tires and rear "bar" (neither R1 nor R4) tires. The chains improve traction enormously in snow and ice and also in mud.
Duo-Link or ring type chains are well suited to AG tires because they cannot fall down between the lugs.
Go to tirechains.com for photos and descriptions of various types of tire chains. Good folks to work with.
SDT
I ended up ordering a set of the euro style for $280 shipped from tirechain.com I really liked how they are put on and just the pattern looks like it would give a relatively smooth ride also look pretty beefy, I checked my clearance and I have around 3" or more all around so think I will be ok that is the only thing I am worried about right now looked like all there chains used the same size 3/8" links so if these don't work I don't think any of theres will. edit: not even 5 minutes after ordering and they already gave me tracking numbers for my 2 priority mail boxes, will ship monday looks like I will let you guys know once I get them and if they work out on my B2320.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #14
I don't know how big, old or experienced your are Notomo, but those suckers are heavy to wrestle onto the wheel. Have fun.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #15
I always viewed a good set of chains like fire insurance. You hope you never need em, but you're glad you have them when you do.
/ Anyone here using chains on there B series industrial tires? Either winter or summer? #16
I ran a set of ladder chains on R4 tires on my old B7500 on all 4 tires 24/7/365 for many years. I still have them if someone needs them and lives near Branson MO.
2006 CATERPILLAR 420D IT BACKHOE (A60429)
2006 CATERPILLAR...
17601CFL (A59228)
17601CFL (A59228)
Chevrolet 2500 Flat bed (A61306)
Chevrolet 2500...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
BUNDLE OF 1 1/2"X1 1/2"X79" TUBING (A60430)
BUNDLE OF 1 1/2"X1...
