Heater Hoses in tractor Cab ?????
/ Heater Hoses in tractor Cab ????? #41
When I installed my heater I did as many mechanics do.
I 'burped' my system by repeatedly squishing the hoses by hand.
Doing that sort of pumps the coolant thru the lines.
My heater is top right side cab mounted and burping worked just fine for me.
/ Heater Hoses in tractor Cab ????? #42
@nvr-enuf - Take that Tee out of there or you'll never get any heat to the heater core. All/most of the heated coolant is going straight through the tee and won't be shared with the heater core. And ditto on not using PVC.
/ Heater Hoses in tractor Cab ????? #43
CCWKen has the correct answer... Hook up AT the water pump bypass Do Not T into it..., remove the bypass hose and connect the heater supply And return to the connections you removed the hose from. You will then have full flow of Hot coolant to your heater core instead of some or none.
/ Heater Hoses in tractor Cab ????? #44
Mike-
I am building a cab similar to yours and I was planning on placing the heater cores near my feet (see attached pics). Doing it the way you described would seem to create a situation where your head is dripping sweat and your feet are frozen.
That's a great redneck way of getting by with minimal cost. When I eventually build my cab, I'll probably do something similar to this. I'd fab a good solid guard for it, as I'm a pretty clumsy guy, and would wreck that thing way fast with my boots! Thanks for the pics!
Chris
/ Heater Hoses in tractor Cab ????? #45
Personally, I'd put in a bypass valve too. Either as part of the heat/AC controls or a stand alone manual bypass. I wouldn't want hot coolant passing through the core during summer. ;)
/ Heater Hoses in tractor Cab ????? #46
Simply put the Original bypass hose back on for summer use, and leave the heater hoses disconnected till Next winter, quick easy and no additional cost.except a few ounces of coolant.
/ Heater Hoses in tractor Cab ????? #47
Is that something you would actually do yourself, or is it just a good idea for somebody else?
I prefer a quarter turn ball valve in a heater hose. positive shutoff, no dicking around with coolant and connections twice a year.
/ Heater Hoses in tractor Cab ????? #48
Mine has 3 valves. One is in each heater connection and one in a bypass line that can be opened to short circuit the water when heat isn't wanted. For warm weather the two valves below the heater are closed and the bypass is open. In cold weather the two below the heater are opened and the bypass is closed. There have been times when I wanted just a little heat and ran with all 3 valves open.
My cab is in sections for easier removal and I did remove it the first Summer after it was completed, but not since then. That required disconnecting the hoses above the valves. No big deal and not much coolant was lost.
/ Heater Hoses in tractor Cab ????? #49
I was talking about the 4-port automotive type heater bypass/control valve used on many vehicles. You can get them in electric, vacuum and mechanical operated versions. The 4-port just makes a loop in the in/out ports on the engine side so the path of coolant returns to normal. You don't have to remove hoses. And, you don't want to just insert a single valve on one hose to stop circulation.
Google "heater bypass valve" and switch to Images. You'll see a slew of different versions.
/ Heater Hoses in tractor Cab ????? #50
Can Not do it with just a Single shut off... It is in the bypass circuit of the water pump, you would need to complete the path for summer use...
And Yes I have been doing that on my 4 cylinder kubota diesel powered ZTR for years, takes only a couple of min, not a big problem simple and almost Instant heat... KennyV
/ Heater Hoses in tractor Cab ????? #51
I don't use the bypass hose.
/ Heater Hoses in tractor Cab ????? #52
Thanks everyone - a friend works at the local (30 mins away) kubota dealer and had a L48 in their shop for service which the tractor did have a cab heater.
Supply to cab heater core is actually the thermostat housing. Right above the temperature sensor which points to the left wheel there is a threaded 3/8" npt fitting which is removed with a number 8 Allen. This is the supply. The threaded plug points to the left rear tractor tire
For the return, I used the threaded plug by the water pump which points straight to the right front tire. Once again it is a 3/8" npt fitting.
Heater works great - lots of heat! Almost too much
I used a maradyne heater I bought off of ebay or amazon. Only mod I did was to change the copper pipes to point straight down vs 90 as built. This made it better for my hose routing
/ Heater Hoses in tractor Cab ????? #53
I would never run anything but metal pipe carrying engine coolant inside the cab of any vehicle.
This is not an efficiency issue, it is a safety issue. If you have ever seen a heater hose let go under the hood of a car, the entire engine compartment is sprayed with boiling hot coolant and steam. If this were to happen inside the cab, the very best outcome would be incredible scalds and years of skin grafts.
If the vehicle were moving at the time, or if you were performing some critical maneuver with the tractor, the chances of a serious vehicle accident in addition to the scalds would be very high.
Curly Dave, Want you to know that I read this post a while back and it prompted me to think about my setup. My heater core sprung a small leak, so I replaced it yesterday. The original core was aluminum and now the same model / same replacement part# comes in copper. This was a great time to revise the hookup and take hard copper outside of the cab for the hose connection. It ended up being a cleaner installation as a side benefit. The white dusty-looking stuff is crumbs from grinding a bit on the Lexan. You may have kept me from getting scorched. Thank you.
/ Heater Hoses in tractor Cab ????? #54
Nvr-enuf
Would you more being more specific. You are saying the l48 application worked on your stat and WP? I ma trying to look at a schematic to install the 3/8npt on my l3901. This would be a huge help to me to figure out.
Good thinking on changing to straight down. That clears up the clutter and sends the line down behind the seat to the outside in an easier fashion.
/ Heater Hoses in tractor Cab ????? #55
My kubota engine ( l39 )threads were 3/8 bsp not npt. Can you get more than 1 1/2 turns? I got fittings from mcmaster carr.
/ Heater Hoses in tractor Cab ????? #56
I'll add two comments:
a) Heat rises...consider that when locating the heater.
b) If you're going to add a cutoff valve (to shut hot coolant to the heater during the summer months), put it outside the cab.
I have a Curtis cab with the factory heater...came with the tractor when I bought it. It's mounted on the right side approximately level with the loader joystick knob which still allows viewing out the lower right front window (handy for mounting and dismounting the loader).
As someone one in an earlier post, Curtis pre-punches holes for the heater lines. Puts out decent heat, but the Curtis cab on my tractor has plenty of openings to the outside, so I don't get too too hot....reasonably comfortable though. The cutoff valve is located inside the tractor's cab...makes it hot during the summer months, even with the valve closed. I thought about moving the valve, but I think during warmer weather, I'm just going to remove the doors this year.
/ Heater Hoses in tractor Cab ????? #58
L39 TLB 2007 ~450 hours This last year (2017) I added a Laurin cab. I tapped into the ports they recommended and I get heat only after the thermostat opens. Will re-examine after this winter season.
/ Heater Hoses in tractor Cab ????? #59
I wish I knew who "they" are because Kubota does not take calls and my dealer either knows nothing about the tractor or is hiding it from me. I am 2 hours from an interstate and if I open things up in snow season I have a long day ahead of me. I spoke to the dealer today about the ports and he suggested I use the block heater port...smh. I really appreciate your feed back. On the next warm day I'll start disassembling to take a look. No way my hands will fit in there and my eyes are worse. BTW, if the in port to your heater is after the water pump the heat will be faster. If you reverse the order some heaters will lose 75% of their efficiency.
/ Heater Hoses in tractor Cab ????? #60
The "they" in my case was Laurin staff who told me and had included a picure of the engine tap ports for connection the heater hoses. But it was designed before Kubota added the recirculation line to help the block heat more uniformly. But my manual says that recirculation line is closed when the thermostat opens. Seems that it is left to the student to figure out the best connection points. Sharing on this forum will help. Warm weather project.
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
