5" Angle Grinder
/ 5" Angle Grinder #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I decided I need 1 or 2 additional angle grinders and I am wondering if anyone has moved up to the 5" models from the 4.5" size. I need one that i can really lean into when grinding and one that will work a little faster than the 4.5". I don't want to get into the big 7" ones because of the price.
Are the 5" ones worth the extra money?
/ 5" Angle Grinder #2
If you want one you can lay on, look at the amps more than the size.
5" are nice cause sometimes that bigger wheel or cutoff disc gets areas a 4.5 won't. That's the only advantage I see.
I have 4.5 grinders that are 4.5a, 6a, 7a, 9a, and a Milwaukee that is 11a.
My only 5" is 9a.
Also have a metabo 6” at 12.2a
Look at 6” grinders. Same size as the 4.5 and 5 inch, but more power.
/ 5" Angle Grinder #3
If you want to lean into a grinder get at least 10 amps and the 39.95 special isn't the one you want even it's 15 amps.
/ 5" Angle Grinder #4
I have a big 7" one that you can lean into. I don't use it very often. I much prefer to work a little longer with my 2 pound air grinder vs using that 15 pound behemoth.
/ 5" Angle Grinder #5
I'm with Arc and LD on this... need the power to lean on a grinder. A 5in will not give you necessarily more than a 4.5in... look at the amps comparing 110v models. Looking at the label for amperage is about the first thing I do when evaluating electric tools.
/ 5" Angle Grinder #6
+1 on the Metabo bought at a rigging company auction for 60.00. Used as a grinder. Other brands get the wire brushes.
/ 5" Angle Grinder #7
I can lean into my Nitto Kohki 4 1/2"" angle grinder. One horse power.
Didn't feel like going out to the shop to snap a pic but here's a link.
Just noticed its discontinued....
Nitto Kohki - MAG-45 / 50 Right Angle Grinders
Terry
/ 5" Angle Grinder #8
/ 5" Angle Grinder #10
Wow, 30cfm. Better have a big compressor or you ain't grinding long.
I have a 100 gallon compressor with about 20 CFM, and you still ain't grinding long. Unless you have a big diesel compressor or something similar that would be about worthless. I don't think you could get there with 50 amp 220. That is solidly in 3 phase territory.
/ 5" Angle Grinder #11
The best grinder I ever seen for really leaning on is the Black & Decker Wild Cat. I understand DeWalt has taken over the name now. Still not a bad grinder. Far has the 4 1/2" grinder I don't give them much thought. I use them until the smoke gets loose, then buy another one.
/ 5" Angle Grinder #12
I have an old metal bodied black&decker like shield arc posted. That thing is probably 20 old and still going strong.
/ 5" Angle Grinder #13
I had a B&D Wildcat once but it got taken in a divorce so I never bothered to replace it till I bought a 7" elcheapo at Harbor Freight. I don't use it much but when I do, I put on a 9" blade and it handles it well with no stalling. It will sure move some metal in a hurry with that 9" blade. I think the only difference between the HF 7" and the 9" is the size of the guard. I have several of the 4.5" from HF and have never had any trouble with them. I have them from the $9 (I got from my brother in law) to the $30 one with the paddle switch and they all work well but just like any brand, if you stall them, they will overheat. I don't use my 4.5" grinders for heavy grinding anyway so I never have that problem.
/ 5" Angle Grinder #14
My big B&D I use only for polishing now. No matter how I position my workpiece height, reposition my posture etc grinding still bugs my back.
I attribute it to old age but realistically I need to learn to weld better ;D
Terry
Edit: hmmm can't seem to be able to post pic...
/ 5" Angle Grinder #15
I never noticed 5 inch grinders before and had no idea they existed. Are the disks readily available? Do they cost close to what 4.5 inch disks cost?
I have two 4.5 inch Makita grinders. I've had quite a few other brands and they all died rather quickly. If these ever die on me, I'll replace them with the same brand. Makita has been very good to me.
/ 5" Angle Grinder
I have a cut-off wheel on an air die-grinder and a couple small grinders for sanding and brushing, and a 4.5" 11 amp Milwaukee. I thought maybe the 5"-13 amp grinders disk tip-speed might be a little faster but it sounds like it may be just heaver and bulkier. That is why I was asking. It looks like the 5" averages about $20 more than the 4.5 so that is not a problem.
I guess I will stick with the 4.5 for the next one...... are 5 grinders enough? :laughing:
/ 5" Angle Grinder #17
For years now I have had several of the HF xx222 and xx223 (easy to remember numbers :) ) grinders. All work as good as new. A neighbor borrowed one with a wire cup brush and cleaned up the entire metal roof of a 14x60 mobile home. It still runs fine.
Bruce
/ 5" Angle Grinder #18
I have three HF 4.5in grinders. The first thing I do is pull the head off and throw a blob of grease inside. They come almost dry.
/ 5" Angle Grinder #19
My "heavy duty" Milwaulkeee came like that...
Terry
/ 5" Angle Grinder #20
All the 5" grinders I have used are not heavier and bulkier than a good 4.5" grinder.
Big advantage is cutoff discs and stones last longer. more meat in them
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
CASE IH 290 AFS MAGNUM TRACTOR (A64280)
CASE IH 290 AFS...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
