Pulling with Three Point HItch
/ Pulling with Three Point HItch #1
KennK
NE Wisconsin
John Deere 3320
I searched through existing posts and was kind of surprised not to find much about this ...
Basic tractor safety says that I'm supposed to use the drawbar for pulling in order to prevent the tractor from flipping front over back.
In earlier posts I've read people seem to suggest we should avoid using the Three Point Hitch for pulling, but then I see videos of people using a plow (moldboard, chisel, ...) attached to a 3PH. Isn't that really an extreme version of pulling using the 3PH?
I understand the concern that using a 3PH to tow a improperly weighted trailer such the hitch could pivot upward and the 3PH - with no down-force or chain to limit upward movement -- could lift the rear of the trailer ... but I am always careful not to rear-load a trailer (well, now I am ... after learning my lesson the hard way hauling long lumber on a short trailer).
Are there other risks associated with pulling with a 3PH that I haven't mentioned?
/ Pulling with Three Point HItch #2
Three point hitch is made for pulling but not made to hold anything down. The risk comes from situations that can lift the hitch, like a low tongue weight trailer, or a properly loaded trailer and downhill braking, especially while turning on rough ground.
Or think about pulling a log or boulder from a three point drawbar. All is OK when the drawbar is in the low position, but the log gets snagged, you raise the hitch trying to free it, and now you are pulling from near axle height instead of down low.
Bruce
/ Pulling with Three Point HItch #3
Any pull above the center of the axle will exert upward lift on the front tires. A plow hooked to the 3ph when lowered is pulling at or just below the center point. Provided the plow is adjusted properly and the top link is not doing the pulling.
/ Pulling with Three Point HItch #4
I can remember Dad and his 8N pulling a large 4 wheel trailer made by John Deere. The 8N's don't have a fixed drawbar so it used the 3PH drawbar which raised up to full height everytime we stopped or backed the trailer up. This didn't affect the trailer load other than raising the tongue up but is was always an issue of slack in the pulling that could jolt anything on the trailer plus the tractor. We never had an issue with the trailer but it was all low speed travel and not much hill other than the occasional crossing of a small swale for drainage in the field. I definitely wouldn't want to pull a 2 wheel trailer or any trailer with a fixed frame/tongue if using the 3PH with a drawbar.
/ Pulling with Three Point HItch #5
I think most people get into trouble with 3ph's by as Gary stated pulling single axle trailers with heavy tongue weight or trying to pull an immovable object. Such as stumps or large logs.
/ Pulling with Three Point HItch #6
As far as I know, the only safe way to do it would be with stabilizer bars running from the top link down to the lift arms, which would keep the arms forced down
/ Pulling with Three Point HItch #7
Pulling a plow is a different situation because the resistance to motion is applied below ground, while the tires [always] apply force at ground. ... There can actually be a net downforce on the front of the tractor in this situation. The plow pulls on the lift arms and pushes on the toplink simultaneously. Resisting below ground favors a net forward lever on the tractor body.
In other pull situations, esp where only hooked to the lift arms, the front is always lightened - and the ability of the arms to rise easily presents no natural limiting influence on a back tip.
In contrast, the fixed drawbar is forced increasingly downward in a backtip and causes a natural decrease in the tipping leverage.
Thanks for the replies.
I feel better now knowing more about the physics involved. It looks to me like if my JD 3320's rocker arms are fairly level or lower then most of the pull will be from below the rear axle - which I think should be safe - assuming there is no uplift force on the 3PH.
/ Pulling with Three Point HItch #9
I am not advocating pulling from the 3ph, draw bar would be better. However you could fill the front bucket with heavy objects (concrete, dirt, rocks) to help hold the front down if there is no other way.
/ Pulling with Three Point HItch #10
Agree that as a general rule it is NOT a good idea to pull with the 3pt hitch.. Ground engaging equipment, plow, disk, chisel digger are a whole different thing..
But to pull a 2 or 4 wheel trailer for instance is a bad idea.. In that it can over run the tractor, push the 3pt to the top or farther than its normal travel and in some cases do damage...
Not that being said I used my tractor with a 3pt receiver hitch to move a lot of boats and pontoons around a yard and in and out of buildings.. I put a chain from the receiver hitch to a shackle on my draw bar so the 3pt could not be pushed higher than it would go under normal operation.. Worked well enough..
For skidding logs, I have a short telescoping boom pole (12-20") that pins to the top link of my receiver hitch implement.. I lift the end of a log with that and use another chain to the draw bar to pull the logs with.. Takes a little extra time and trouble, but I have had no issues with this way of doing it..
Keep safe..
/ Pulling with Three Point HItch #11
Keep safe..
This is an excellent method.
/ Pulling with Three Point HItch #12
I wrapped a chain around the middle of a 3pt hitch drawbar. The drawbar got turned so the flat side was up and down, Then, I pilled another tractor. Now my drawbar has a sway in it.
/ Pulling with Three Point HItch #14
Thanks BCP I wish I'd had one on the day I bent my drawbar.
/ Pulling with Three Point HItch #15
Harry Ferguson invented the multi-component Three Point Hitch during and after WWI. He obtained international patents mostly in the period 1932-1936. When implements are mounted on Ferguson's 3-Pt., most of the implement weight is transferred to the tractor's four wheels, improving traction.
Prior to Ferguson's 3-Pt., which included hydraulic lift, Draft Control and centered PTO, implements were often pulled with chains, and tractors, though commonly weighing several tons, often went vertical, then toppled over. With the 3-Pt. tractors could be much lighter; viz the Ford 8N, 9N, etc. ( Fergunson's first major licensing agreement.) Ferguson's patents expired, serially, in the mid-1950s.
Utility size tractors usually include Draft Control as standard equipment.
New plows sold for smaller tractors, which commonly do NOT have Draft Control, have either a trip mechanism or shear bolt protection to decrease the chance of a vertical tractor.
When skidding timber from the drawbar or cross-drawbar you have little or no load transfer to the tractor.
As I was learning about tractor operation I once got a Deere 750 (20-hp) completely vertical when skidding logs from a cross-drawbar. Luckily I had my seatbelt secured. Pulled log stopped against a protruding root and the tractor pivoted around the rear axle in 1/2 second. I NEVER want to repeat that. So, you should elevate the tractor ends of logs being skidded 4" to 6".
Two of use detached the logs and used the chain to pull the tractor back to horizontal without damage to the tractor.
Drawbar T-frame in photo is from OMNI Manufacturing.
LINK TO HANDI HITCH: HANDI HITCH ACCESORIES
/ Pulling with Three Point HItch #16
/ Pulling with Three Point HItch #17
Here is Handi Hitch's version of a Short Boom Pole: SHORT BOOM POLE ADAPTER
Available from Agri Supply.
/ Pulling with Three Point HItch #20
I got this hook from TSC.
Since a 3pt only lifts and a load can push it up causing serious problems, wouldn't you think that, long ago, some genius, could have figured that putting a double action cylinder in the 3pt lift system would be the thing to do?
3147 (A63117)
3147 (A63117)
2020 Cushman 1200X Gas Utility Cart (A66734)
2020 Cushman 1200X...
JOHN DEERE 9420R ARTICULATING TRACTOR (A65057)
JOHN DEERE 9420R...
1995 TIGERCAT 726 FELLER BUNCHER (A65056)
1995 TIGERCAT 726...
2015 KENWORTH T680 (A67714)
2015 KENWORTH T680...
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
