LED Garage Lights
/ LED Garage Lights #21
hoping someone will post links to good LED garage lighting. My issue with the LED's I have used is they cause too much havoc with my AM radio.
What brand do you have Dragon.?. I can't find much of anything coming out of my Cree's. Including the 530-1700 Khz. band. Now I am using an outdoor wire antenna that is a few feet running over the house, not an inside the radio "loopstick" antenna
/ LED Garage Lights #22
I just thought of one downfall of LED's. I sometimes wonder how much heat we get from an incandescent bulb verses an LED.
What I think is in the home, during winter months we should run incandescent bulbs in lamps and lights, getting both heat and light from them. Then during summer we should run LED's. I don't think anyone will ever do this, but for sure we do not get any heat from LED's being used.
/ LED Garage Lights #23
I just thought of one downfall of LED's. I sometimes wonder how much heat we get from an incandescent bulb verses an LED. What I think is in the home, during winter months we should run incandescent bulbs in lamps and lights, getting both heat and light from them. Then during summer we should run LED's. I don't think anyone will ever do this, but for sure we do not get any heat from LED's being used.
That's not a downfall. Those old incandescent bulbs give off plenty of heat all the time including when you are paying to run the air conditioner. With the substantially more efficient LEDs you can use that energy you saved to run a heater. I'm guessing even an electric heater is more efficient than a light bulb for heating. I heat my house with wood and the shop with natural gas. Both are drastically cheaper heating options than a light bulb.
/ LED Garage Lights #24
After reading this thread, I went to Costco and bought 2 of the 4 ft. LED fixtures for my garage, which had 6 spotlights in it. Huge difference, much better visibility into the nooks and crannies where all the nuts and bolts and various shop chemicals are stored.
Definitely going to get some for the barn. I have 2 LED spots in the barn already, but they don't put out near the light that the tubes do.
/ LED Garage Lights #25
I have three 20 watt 6000k LED floods along the 40' wall of a 30x40 pole barn and they bring the whole place up to "usable" light levels (bright enough to see what you are doing and to read by if you wanted).
I am going to mount four 50 watt 6000k LED floods over the "work bay" and that should really light things up.
Aaron Z
/ LED Garage Lights #26
Wow - AM radio as a lighting consideration. To make good decisions in life ya gotta have good light AND keep up with the facts !
What that has stopped me in buying LED shop lights was:
1) I have too many new fluorescent light tubes that I bought on sale.
2) Will brightness be equivalent to the fluorescent lights I'm replacing?
The ones I bought are advertised as "1900 lumens, 4100k daylight color ". Anyway, two 1900 lumens (=3800 lumens) LEDs are brighter than two 4 ft fluorescent tubes.
/ LED Garage Lights #27
Wow - AM radio as a lighting consideration. To make good decisions in life ya gotta have good light AND keep up with the facts ! What that has stopped me in buying LED shop lights was: 1) I have too many new fluorescent light tubes that I bought on sale. 2) Will brightness be equivalent to the fluorescent lights I'm replacing? The ones I bought are advertised as "1900 lumens, 4100k daylight color ". Anyway, two 1900 lumens (=3800 lumens) LEDs are brighter than two 4 ft fluorescent tubes.
The LEDs will be way brighter then the fluorescents. I haven't replaced any fluorescent lights yet. I have upgraded almost the whole house to LEDs. The LEDs were way brighter then the 75 watt can lights they replaced. The LEDs are so bright I haven't put them in my bedroom because I don't want to be blinded by them.
/ LED Garage Lights #28
They are not CREE and in fact were intended to light a saltwater reef aquarium. I had some a few extra 'demo units' that I imported to sell also to others. These things are super bright and in a special reflector, the LEDs are white and a few blue totaling 160W. They have a separate power supply and timer and a fan in the LED housing! Mounted one over a workbench but when on, really messes with the radio. I like to have the radio on in the background sometimes but that is a lost cause. I want to convert over my fluorescent tubes but wondering which are RF interference free.
/ LED Garage Lights #29
I suspect the power supply is the problem.. undoubtedly a "switcher".
Look for a rating on the power supply and replace it with a conventional transformer based linear supply with comparable ratings. and you problem would disappear.
/ LED Garage Lights #30
A incandescent bulb is going to be the same efficiency as any type of electric resistance heat. Weather that be portable fan-type heaters, oil filled, radiant type, baseboards, heat strips in the furnace, your oven, etc.
If you are using electric as heat in the winter, then there would technically be no cost savings in the winter to run LED's. But electric resistance is the most in-efficient electric heat. Heat/pumps and geothermal give 2.5-5 times more heat out per watt. And some heat with wood or propane or NG. Thats when led's are better
/ LED Garage Lights
OK, I went to Lowe's and bought a 4 foot LED light today for $45. This 4 foot LED light gives off 3,600 Lumens of light and is a lot brighter than the 8 foot double bulb Flourescent light it replaced. It is a flush mount light. There are no bulbs to replace ever. They claim to last up to 35,000 hours. It is a 40 watt. I need 3 to 4 more them. Anyone need to buy some old used heavy 8 foot double bulb flourescent garage light fixtures?
sherpa
/ LED Garage Lights #32
I'm at Costco now. Buying 4ft LEDs with fixture for $29. Was just going to buy bulbs but they were on sale at same price so going to add more lighting to garage instead! Will compare brightness and RF interference this afternoon.
/ LED Garage Lights #33
I just did some looking at those led tubes. I have a question.
How does the light output compare to flourescents?
I noticed the prices have come down a bit, and would consider them, but the numbers don't make sense.
The leds seem to be somewhere between 16w and 20w and right at 100 lumens per watt.
So to keep things simple, let's compare 16w/ 1600lumen/ 5000k
My t8's are 32w 5000k, and 2800 lumens.
I currently burn 64 bulbs when in the shop. (8 6- bulb fixtures and 4 4- bulb fixtures). That's 2048w of light and 179,200 lumens
To get equal lumens would require 112 leds, and at 16w each, that's 1792w of power. So for equal light output, only a 256w savings. (12%) far cry from the claims of 50-60% energy savings I am seeing online.
At $8 per tube, and needing 112 of them, for a total savings of 4 cents per hour, they would have to burn 22,400 hours just to break even. Or about 8 hours a day, 5 days a week, for 11 years. Hard to justify.
If I only went with 64 bulbs to replace my existing tubes, I would only have 102,000 lumens instead of almost 180k. So about 43% less light.
I could just remove 43% of my flourescents, down to 36 bulbs to match the lumens of 64 leds. Power would be 1024w for led vs 1154 for flourescents. Not enough to justify the savings. And I really don't think taking out almost 1/2 of my lights will leave it bright enough. Thus the lower lumen output of leds concern me and make.me thin I would need to add fixtures if I went that route.
So, what's the scoop? Is lumens not an accurate eye test? Is there no noticeable difference between two fixtures side by side in the real world?
/ LED Garage Lights #34
I just did some looking at those led tubes. I have a question. How does the light output compare to flourescents? I noticed the prices have come down a bit, and would consider them, but the numbers don't make sense. The leds seem to be somewhere between 16w and 20w and right at 100 lumens per watt. So to keep things simple, let's compare 16w/ 1600lumen/ 5000k My t8's are 32w 5000k, and 2800 lumens. I currently burn 64 bulbs when in the shop. (8 6- bulb fixtures and 4 4- bulb fixtures). That's 2048w of light and 179,200 lumens To get equal lumens would require 112 leds, and at 16w each, that's 1792w of power. So for equal light output, only a 256w savings. (12%) far cry from the claims of 50-60% energy savings I am seeing online. At $8 per tube, and needing 112 of them, for a total savings of 4 cents per hour, they would have to burn 22,400 hours just to break even. Or about 8 hours a day, 5 days a week, for 11 years. Hard to justify. If I only went with 64 bulbs to replace my existing tubes, I would only have 102,000 lumens instead of almost 180k. So about 43% less light. I could just remove 43% of my flourescents, down to 36 bulbs to match the lumens of 64 leds. Power would be 1024w for led vs 1154 for flourescents. Not enough to justify the savings. And I really don't think taking out almost 1/2 of my lights will leave it bright enough. Thus the lower lumen output of leds concern me and make.me thin I would need to add fixtures if I went that route. So, what's the scoop? Is lumens not an accurate eye test? Is there no noticeable difference between two fixtures side by side in the real world?
Very interesting analysis, LD1. Sounds like they may mot be worth it!
/ LED Garage Lights #35
The LEDs don't require a Ballast. I have to replace a ballast every couple of years. It would make more sense to just replace that fixture with LEDs. In maybe 20 years I would have them all changed. In reality they will drop in price, and I will just change them all over in a couple years. The LED bulbs have already halved in price since they came out a few years ago.
/ LED Garage Lights #36
A incandescent bulb is going to be the same efficiency as any type of electric resistance heat. Weather that be portable fan-type heaters, oil filled, radiant type, baseboards, heat strips in the furnace, your oven, etc. If you are using electric as heat in the winter, then there would technically be no cost savings in the winter to run LED's. But electric resistance is the most in-efficient electric heat. Heat/pumps and geothermal give 2.5-5 times more heat out per watt. And some heat with wood or propane or NG. Thats when led's are better
I don't heat with electric. Besides those crapper kerosene heaters electric heat is the most expensive option there is.,My primary heat source is wood which cost about 35 dollars a month to burn. It costs drastically less if I split it, but I pay a guy to split most of it. Even if you did heat with electric why would you go through the trouble of changing the light bulbs twice a year? I would have to store a couple hundred light bulbs of the other type, and forgetting to change back in the summer would quickly eat up the very small cost savings. I think you could save far more money by investing in more insulation, better windows, and more efficient heating equipment then worrying about light bulbs.
/ LED Garage Lights
We are going back to Lowe's Hardware and get 4 more of the 4 foot LED lights:
(40 watt, 3,600 Lumens, last 35,000 hours)
I hope to have them all installed by the end of the day. This is a nice upgrade to the garage. The wife and I spend most of our awake hours doing projects in the garage and I think she is more excited over these lights than I am.
Happy New Year
sherpa
/ LED Garage Lights
I got all 4 of my LED garage lights up. I have one more light that I have not decided where I want it just yet. I will try it in a few places for the most light before I install it. I am ready for 2016 now.
sherpa
/ LED Garage Lights #40
I had been wanting an LED dual headed work light. I've got an old HF halogen.
Voila
Main reason I did it was because it was so hot last summer using the halogens was cooking me.
