ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Well I just finished insulating the ceiling in the shop. What a huge difference. So far it has consistently stayed about 10° warmer in there without running the heater. When I do use the heater it heats up very quickly and holds the heat very well. Much nicer than my old kerosene torpedo heater. I thought I'd post this picture of another idea I came up with. I have a fan from an old furnace that I tore out that I had recently replaced the motor in. I mounted the fan in the ceiling of the barn to act as a ventilation fan. As I have it set up it should suck air out of the barn and push it into the attic. I thought this would be handy on hot days. I'm thinking it will draw hot air from the ceiling and push it into the attic and that should force some of the hotter air allready in the attic out the vents.
Nothing wrong with a ventilator fan in the ceiling if you have a way to close it off when not in use. If it's not closed off, right now it's letting heat out of your building and will continue to do that every second. Furthermore, this warm air from your building will now be condensing on the cold surfaces of your roof. Better to have that fan installed in the end of your building to exhaust outside. Even then it needs to be sealed and insulated in Winter to stop heat transfer.
You'll figure all that out as you go.
