Mini gantry crane
/ Mini gantry crane #41
Look guys we have shielding gas AT THE SITE we so that's NOT THE PROBLEM, THE PROBLEM IS its a weld that does NOT go as deep as smaw. There good in body shops.
/ Mini gantry crane #42
Shielding gas at the puddle, not at the job site. SMAW is a simpler process with less ancillary equipment needed. A power supply, some leads, and a box of rods = good to go! It also performs better in outdoor environments - where you don't have wire liners, spools, guns, feeders, and a power supply exposed to rain and dust.
Keep grasping though. :rolleyes:
/ Mini gantry crane #43
Could load it up and roll it over a pebble and see. Polyurethane might accommodate small pebbles.
Personally I'd load it at least double of the 880 lbs and lift 1 inch, bounce on it, shove it, try to see where it's flexing and brace accordingly.
Ignore the purple brace on the red/white juncture, I drew the pic but now I don't think it provides anything. The load on those 1/2" bolts is a tiny fraction of their capacity.
The rolling legs could have a fold-up brace that swings down and double-pins at center for when you travel it. Or maybe if you ever have a real heavy load just bolt a 2x4 across from leg to leg (at that time). You might get a handle on this by rolling it over a pebble with 2x or 3x 880lbs.
451629d1451099398-mini-gantry-crane-crane-jpg
And you could hang a shower curtain from it. :thumbsup: Don't need a towel with that blow-dry.
I was thinking since I first saw your setup that a chain at near floor level that could be attached when you're in process of moving a load, in advance of course of actually moving/lifting it, could span the two legs and make it so they can't spread apart at the crucial points of moving your load. This could easily be run over by the tractor or truck or whatever, before attaching it to both sides, then again dropped to the floor before exiting the bay with the load already in place in the truck bed or on your forks, etc.
I'm by no means any kind of expert on cranes or welding of any type- just trying to contribute something possibly useful.
Here's a link, just for looking at to see what is done in a 1 ton gantry crane, in case any of the design could be useful to the OP in his application. Please note the leg base supports; granted they aren't able to be incorporated into your crane, but might help in the overall discussion.
1 ton Capacity Telescoping Gantry Crane
/ Mini gantry crane
I hate to interrupt a weld discussion, but I was hoping for some comments on my tentative solution. I mocked up to weld weaknesses with bolts and steel. The top of the legs would have L steel (angle Iron) 3x4 or 3x5 by 7" ( I used a small sample for picture) and bolt thru the 3x6 in two places each plate. There would be 2 on each side -- 4 total. The tee joint weld would have bolts approx to where the black dots are on the paper. I will reevaluate the top of the tee during the drilling of the bottom. I have a 3x3x1/4 stick the if I add tabs to the bottom of the legs- near the caster, I would put in place when ever I am moving a load, otherwise it is stored attached to the outside of the left leg.
Thanks. rob
/ Mini gantry crane
Coyote Machine, Sorry , we were typing at the same time. I think my rigid 3x3x1/4" square tubing will lock the legs sufficiently when needed. see above Thanks
/ Mini gantry crane #46
No problem, just trying to throw out some ideas. Wouldn't a chain be more useful, because you can throw it under a tractor and connect to each leg, whereas something like a stick from the legs won't be able to be put in place if a tractor, truck or dolly is already between the legs area in question?
/ Mini gantry crane #47
Bolting those connections would be great.
The chain suggestion is also a good one, but I'd first verify the cross beam isn't twisting causing the observed spread.
/ Mini gantry crane #48
Couldn't you also go out to one side, on each leg, away from the OH door opening, also supported by a locking wheel to give additional support? This single horizontal leg could then have a welded or bolted or both section going at a 45* angle back onto the main leg, without any of it being in the way of lifting/moving loads. It would be a 1/2 of the support structure shown on the gantry crane I linked to, instead of the double triangles used in that crane support it would be single ones on each leg.
/ Mini gantry crane
I'll add the bolts and steel L's and the 3x3 is bidirectional support versus a chain - unidirection support. But I have chain, so I'll see as the situations arise. I should mention welding justified a new welder, bolting just a new drill.bit:laughing:
Thanks all, rob
/ Mini gantry crane #50
Welding will pay for itself down the road. Need to keep your digits intact for that to work.
/ Mini gantry crane #51
I thin you have a good plan now
/ Mini gantry crane #52
Don't forget that it is also hard to keep the argon in place when welding outside.
Nothing g like laying a nice bead and a breeze kicks up.
/ Mini gantry crane #53
That's what I meant by shielding gas at the puddle. MIG is a great process for welding efficiency, and with modern power supplies and shielded flux core electrodes, you can do some really impressive stuff; it's just not as good of fit standing on an I-beam out in the weather.
Someone PM'd me and said they were a UNION welder and they had all the gear they needed and still didn't use MIG and told me I should go learn about it. :rolleyes: Same one with reading comprehension issues. What a coincidence.
/ Mini gantry crane #54
Many many many structural things get welded everyday with mig.
Pretty much anything that can be built inside a factory. Heavy equipment, industrial lifts, truck and trailer frames, pressure vessels, etc. Many things that if they failed would be catastrophic and likely cost lives.
Mig is a good process. Get so tired of hearing all these "union ironworkers" think 7018 is the only way things can be welded. Or thinking that anytime someone mentions mig, that we are talking about a 110v 90amp machine. I think they need to get educated on more process than just stick before they open mouth insert foot
/ Mini gantry crane #55
you guys have NO IDEA WHAT they have on a construction site! all you know is book theory no real world experience!.
/ Mini gantry crane #56
They have stick welders on construction sites. No one is saying otherwise.
Just disputing your reason as to why. It has nothing to do with penetration. Lots of other thing make stick the better choice.
It seems YOU have no experience beyond stick except maybe a 110v mig. If you did, you would quit saying migs don't penetrate.
Go fire up a Miller 456mp feeding .052 wire in spray or pulse and then tell me mig don't penetrate.
If I were to weld 1" plate with 7018 1/16 rod at 40 amps on a little harbor freight inverter what do you think will happen? What if I used the 456mp/.052 spray mentioned above?
/ Mini gantry crane #57
One of the biggest drawbacks for using a MIG in the field that I haven't seen mentioned is the short leash that the MIG keeps the weldor on. With a stick machine, the work can be 100 feet or more away from the machine. MIG wire doesn't feed so far. We use MIG almost exclusively in the shop and stick in the field and the bulk of the work is pipe (4" - 30"). For pipe over 8" we use the subarc machine when we can. That's an impressive machine. We also fab various stands, hanger assemblies and equipment supports.
/ Mini gantry crane #59
I did mention it. Hauling a power supply, feeder, bottle, and still having to run a power cord up to the work area. SMAW is by far the most portable method of arc welding, it also uses the fewest moving parts.
/ Mini gantry crane #60
Another few drawback when pushing the amps up there and wanting a pretty high duty cycle....
Liquid cool torches
Heavier and bulk guns compared to a stinger and rod
Getting into tight areas
I too am looking forward to learning more about stick being better penetrating and thus the reason for its use in construction. Because nothing I know about welding tells me this.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
8063 (A61166)
8063 (A61166)
2019 Chevrolet Tahoe 4x4 SUV (A61569)
2019 Chevrolet...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
New/Unused 11ft x 19ft Metal Garage Shed (A61166)
New/Unused 11ft x...
