dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,703
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Proof testing ductile materials like steel/alum is risky. You can overstress the material but yet not fail it. If you do that, the material is permanently damaged and can then be weaker causing a failure later on. Proof testing is generally only done on brittle materials like ceramics where they either survive or fail. There is no risk of "some damage" that makes it weaker but you cannot tell. Be very careful in orverstressing metal assemblies. If you are designed 5:1 and you overstress 2:1, then odds are you are fine (IF you welded things right, with the right materials and processes), but if you start pushing 3-4:1, then you are risking hidden damage in a non-certified assembly. And this is a guideline, not a hard ad fast rule. Again, proof testing metals is a sketchy prospect at best.
