Bending a snow blower?
/ Bending a snow blower? #1
BWSwede
Washington
Yanmar
I've got an 84" Farm King snow blower. I have it mounted on the front of a 10,000 pound 100 hp 4wd tractor with chains on all 4 wheels. I am wondering if it is possible to damage the snow blower by making say a 1 or 2 foot cut into a icy snow bank along the side of the road in an attempt to widen it.
The tractor will push incredibly hard and it seems to me that if I am not careful I could bend the side of the blower back toward the tractor when cutting back the bank. Although it seems this could happen I have never heard of it happening to anyone.
What are your guys' thoughts on this? Any body have any experience with this?
TIA,
BWSwede
/ Bending a snow blower? #2
I'm sure if you push hard enough - there will be damage somewhere. In the situation you describe - I would put the tractor in as low a gearing as possible and let the blower "eat" its way thru the snow bank. Otherwise - figure some procedure that breaks the snow bank first then come thru with the blower and clean up the chunky,broken snow.
I've only ever had a 3-point pto driven blower and when the berms along my driveway got hard & crusty I'd gear down as low as possible and chew thru it.
Your situation sounds like its a problem of breaking up the berm/bank first and not blowing the resulting broken up snow.
/ Bending a snow blower? #3
I move the frozen stuff (such as Bane describes) with my 3PH blower. The main thing is to go slow and let the blower work it's way through. The augers will nibble through quick enough.
As far as damage...other then breaking a shear pin, I'd doubt it would be anything worse.
/ Bending a snow blower? #4
I think timing is your friend here - if you can get at the banks before a major thaw and refreeze turns them solid will be vastly faster and easier. I think there will be a certain level of frozen solid that will either damage equipment or break shear pins and/or be so slow as to be impractical. With that size machine a rear blade with offset would likely be a better tool for really frozen banks. Even a FEL could be easier though tedious as well.
/ Bending a snow blower? #5
I'm voting for the break it up a bit with a bucket then clean up with the blower.
/ Bending a snow blower? #6
I think unless it is really frozen you won't have much issue if you are careful. What I could see being the issue is getting one of the side plates into a hard bank and steering with a lot of traction, a lot of side loads on the rather unsupported side plates of the blower.
/ Bending a snow blower? #7
I've found that unless you have a tooth bar mounted on the bucket, the FEL doesn't do well breaking up frozen piles of snow.
Thanks for the replies guys.
A couple things to note. I do not have a front bucket or backhoe to break up the ice chunks. I also have found that since the auger housing is about 30" tall and the auger is about 1/2 that there is about 15" above the auger that allows the ice to ram up against the back of the housing. It seems that no matter how slow I go, which can be really slow, I can still feel the blower trying to stop forward motion of the tractor.
Ideally, it would be nice to have a second auger above the current auger. That would prevent the latter condition above. Has anybody ever added a second auger to their blower?
Thanks again,
BWSwede
/ Bending a snow blower? #9
Good point roy, I guess I forgot that I have a bigger than average tractor on here. If I can get a corner of the bucket into it, I can usually get most things dug up.
/ Bending a snow blower? #10
...If I can get a corner of the bucket into it, I can usually get most things dug up.
I'd be mighty leery about doing that with any sized tractor with a QA loader...
But, if it works for you. more power to ya!
/ Bending a snow blower? #11
If you are going snow blower speed you won't have an issue, if you are ramming it.....well, something has to give.
I am guessing tractor will spin out, literally (pivot sideways) before it will bend the blower up.
I'd watch the 3pt frame/pins of the blower first. My old IH 70 had the pins bent backwards when I got it.....
/ Bending a snow blower? #12
I've seen quite a few "tweeked" blowers. Frozen snow/ice can provide as much if not more resistance than dirt. Would you back your blower into a pile of dirt? Structurally, there's not a lot of support from the center 3 pt. area, to the extreme edges of the blower. The auger can be bent and then it will rub the front "wall" of the blower making a wonderful noise with each revolution.
I think I need to reinforce my Farm King like this Lorenz. Check out the angled braces at the top and bottom of each side. The Farm King, and most other blowers I've looked at don't have these. Without these there is about a 3' leverage from the center of the blower, where it is supported, out to the side.
BWSwede
/ Bending a snow blower? #14
Well I don't have the factory bucket for one, I got an hd one and generally just pushing into the bank is more than enough to break up and ice. Pushing with a 10k+lb tractor with chains it's no big deal moving icy snow banks. I usually start square up if I have enough room but I don't hesitate to put a corner in and push on through.
/ Bending a snow blower? #15
A snow blower takes a light touch. Thread lightly. Icy snow banks are hard on gear boxes, shear pins as well
TIA,
BWSwede
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2012 Ford F-450 4x4 Altec Bucket Truck (A66736)
2012 Ford F-450...
