how should I flush hydraulic fluid?
/ how should I flush hydraulic fluid? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So I recently bought a used Woods backhoe attachment. I do not know the service history.
Before I put it on my hydrostatic MX4800 in the spring, I was thinking I should flush out the old hydraulic fluid so as to not contaminate my UDT2.
Several people were nice enough to describe how they have done it here:
http://www.tractorbynet.com/forums/attachments/349544-how-i-mount-bh90-x.html
What they describe seems like a major PITA!.. But may just be the way it goes.
Anyone have an easier way?
I will not be able to mount the hoe to my tractor prior to flushing it.
/ how should I flush hydraulic fluid? #2
When I bought my BX used the service history was questionable at best. The fluid was pretty dirty. I used UDT to flush the system and replaced the filter then flushed the system again before putting SUDT2 in.
The old oil was so dirty the FEL was having problems with flow through the control valve.
/ how should I flush hydraulic fluid? #3
I would change the HST oil in your tractor then flush the backhoe with your old oil, killing two birds with one stone.
Good luck, Fred
/ how should I flush hydraulic fluid? #4
I'd hook an air compressor to the pressure line. Pull the pins on the rod ends of the cylinders and cycle the cylinders with air. Should blow most of the oil out the return line which hopefully you've put in a container of some sort.
/ how should I flush hydraulic fluid? #5
I use a method that works well for me when flushing dirty or water contaminated systems. First, drain and refill, drain and refill as needed, the tractor alone, without operating any external cylinders. (In your case, that part would not be necessary) Next, remove the sump return hose from loader (or in this case backhoe) valve and drop it into a bucket. Start the tractor and cycle each cylinder system one at a time. The oil returning from cylinders and related lines will go into the bucket and not back into the tractor. Cycle each system as needed until the oil coming out looks clean then move on to the next circuit. With small tractors, fresh oil needs to be added frequently, but the end result is clean oil throughout, with a minimum of mess, and a lot less effort.
Good luck, Fred
My expensive SUDT2 fluid is not due for a change so hooking up to the tractor system that's not really a good option for me.
What fittings do you use to do this? Is blowing seals a problem?
Ok, interesting idea. Anyone else done this?
/ how should I flush hydraulic fluid? #9
seals a problem?
Air pressure will not blow any seals, as you are using only 100 psi or so. What MAY
happen is sudden mechanical movement as the pressure builds up enough for
a cylinder to extend or retract. Be careful if you do it this way.
I have not done it this way, but I have used air pressure to disassemble cylinders,
and that can be dramatic. And dangerous.
I have only flushed implements (hoes and FELs) with external mechanical force
applied to them to articulate all the cylinders and collect the fluid via the tank
return hose. Doing this dynamically with the tractor hyd pump running would
work, but I have not tried it. I don't want to lose too much clean expensive fluid.
/ how should I flush hydraulic fluid? #10
Luke, not my son, this is your father, Darth....;)
Here's my idea, not sure if it would work with the pressures needed to get the fluid out/through the circuits/cylinders but here's the theory-
rent a (sump pump, ? or similar), that could push clean hydraulic fluid from a 5 gallon bucket into the inlet hose of the hoe. Cycle all the levers/valves on the hoe to allow fluid to flow in, then use the return to tank line for the 'waste' oil coming out into a separate bucket. Do this until you are seeing fresh clean hyd fluid coming out the return line.
You may have to work out what type of pump would get the job done, but there has to be something available on the cheap- you're not trying to run the hoe, merely trying to push fluid through the circuits- not sure how much pressure that would require?
/ how should I flush hydraulic fluid? #11
blown seal?
ag hyds usually operate around 2500 psi
Most air compressors operate between 120 and 150 psi.
Does your air compressor put out more than 2500 psi?
If so.. I'm impressed! :)
blown seal?
Well my assumption is that the packing is designed for viscous hydraulic fluid not nitrogen gas. So a PSI is not necessarily a PSI.
/ how should I flush hydraulic fluid? #13
and??? what's the possible worst that will happen.. a temp air leak?
remember.. again.. the seals are designed to contain 2500 psi of essentially uncompressible fluid...
150 psi of quite compressable gas is laughable.... hard to even make a comparison really.
Ya, it just occurred to me that the hoe valve bank is probably open center so I'd be loosing 12+ GPM of good fluid from the time I start the engine (and not just when I actuated a valve)!
Is my thinking correct?
If so, I'm back to manually cycling the pistons or using air.
I wonder what the large dealers do?
/ how should I flush hydraulic fluid? #15
Not a danm thing, I will bet.
You will lose some fluid if you run the tractor. Even at idle, prob 3 GPM thru the open-center
valve. Too much? That's your call.
/ how should I flush hydraulic fluid? #16
The suggestion I offered was intended for use with an open center, power beyond type system, using a third, sump return line. In which case no oil flows through this line unless a valve is in use. If your hoe has only two hoses connected to tractor hydraulics, that's a different matter. As for the listed methods for removing existing fluids from cylinders and lines, I'm sure any/all of them would be effective. I made my comments based on your first post, in which you asked about a simpler method.
Harry, I really appreciate your help and did not mean to ignore it. On my Case 680s there was 2 return lines. I'll have to go out and look at the Woods hoe this weekend when I'm home while it's light. There are only two lines connected to the tractor but the return lines may Y together upstream.
I does make sence that there should be a return line from the valve assembly when all the valves are closed and another return line from the cylinders. There would only be fluid returning from this second line when one of the valves is opened.
Am I thinking about this correctly?
What are the proper names for these lines? Sump return and.. ?
Will it be obvious which line is which or can you give me some tip to identify which is which?
Again thanks!
/ how should I flush hydraulic fluid? #18
Where I have been working, we use compressed air to remove oil from cylinders, before, and after, rebuilding them. As well as, compressed air to initially test them.
A blow gun with a rubber tip, and a rag, usually works fine, on the inlet, or outlet threads.
Yes, you would have to break a lot of lines loose. But, everything is pipe thread once you remove the couplers, and hoses, just like air fittings, so it's not hard to cobble up something that you can couple up to.
Low pressure is recommended. This is due to the fact that it will cause rapid piston movement, and lots of flying oil.
Ok cool. Rubber tip seems simple. What's the rag for? What do you consider low pressure?
/ how should I flush hydraulic fluid? #20
Woods hoes and all other CUT hoes I have seen have only 2 lines, IN, and OUT. AUX valves
sometimes have a third line call Power-Beyond. Industrial hoes usually have more lines cuz
they use 2 pumps (swing, and boom/dipper/bkt). Except the B21 hoe, it has only 2.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
Caterpillar 950B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950B...
UNUSED TAG BTB12518 - 18" PIN ON BUCKET (A64280)
UNUSED TAG...
2011 Porsche Panamera Sedan (A61574)
2011 Porsche...
Informational Lot - Shipping (A63688)
Informational Lot...
