I'm building a wood shed....I need some help
   / I'm building a wood shed....I need some help #41
I might have missed it... but I always setup string and square that up before digging any holes. As for squaring up, (1x) 3,4,5; (x2) 6,8,10; (3x) 9,12,15; (4x) 12,16,20; (5x) 15,20,25 The longest you can do the more accurate I think it is.
You can still do the string thing at this point you.
   / I'm building a wood shed....I need some help #42
So General Lee, Did you ever get it squared up?
   / I'm building a wood shed....I need some help #43
I'm building a similar size shed and just want to mention recycled lumber.
In both Mississippi and Northern Virginia there are a few places that sell wood from torn down buildings at about half the price of new "big box" stores. It's straight and not going to warp. And I can go up a size (2x8 vs 2x6) at little cost.
I sure did, Just came in finishing up the back 3 posts. I did what you suggested and pulled 12' and 232 1/4 and marked it. Sure didn't look like it would line up with the other post but when I did the same on the other side and measured my width, BOOM 16'. I have learned so much so far from you guys replying and helping out. Thank you guys.
Tomorrow I'll start the header work. I did upgrade to 2x8's, went and picked some up this afternoon.
I also did what Eddie and others said I believe, I went and got longer posts. Set them in the hole and called it a day. I will cut off the excess as needed instead of trying to get them all the same height.
   / I'm building a wood shed....I need some help #45
I don't know what you have for saws, but when I cut posts, I measure and mark then where I want them cut on all four sides. Then I make my first cut using my cordless circular saw on all four sides. This leaves me with about a 2 inch section of solid wood in the middle of the post that my circular saw wasn't able to get to. Then I finish it off with my cordless sawzall using a 9 inch demolition blade.
   / I'm building a wood shed....I need some help #46
That's how I cut posts that I want to look nice and purdy for deck rails or similar.
For a polebarns...its the small chainsaw
   / I'm building a wood shed....I need some help #47
Yep :D actually other than chipping/rough cut I use mine on anything more than 4x. I makes all kinds of things from logs though, so I've had lots of practice. I must advise for most people chainsaw+ladder=ER. I wouldn't try it if your not very used to running a chainsaw.
   / I'm building a wood shed....I need some help #48
General,
I would suggest building a working platform. (if you have pallet forks) I built this one from just scrap wood before building my barn. It was used as much as any tool I had.
Yes, I plan on using my pallet forks w/ a pallet as a platform to work off of using my Kubota. Some work will probably be off a ladder too.
Eddie, for saws I have a cordless circular, saw zall, chain saw, and electric circular if I want to drag out the generator to the work site. For notching the posts for the header I will probably use the cordless and the clean up the cut w/ a hammer and chisel.
   / I'm building a wood shed....I need some help #50
For notching my posts, I draw my lines and use my cordless circular saw to make my first cut. This gives me a very straight line. Then I finish it off with the cordless sawzall using the 9 inch blade. This eats up the battery, so when I'm doing a big deck, I will have all three charges out with batteries in them. There is no need for a chisel and the results are perfect every time.
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
BUNDLE FENCE PIPE (A51244)
BUNDLE FENCE PIPE...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2121 (A51244)
2121 (A51244)
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
