engine seized or hydraulic lock?
/ engine seized or hydraulic lock? #41
I'd for sure eliminate all those things before I started disassembling the tractor/engine. :)
Good lord yes. Check the easy stuff. I can't believe it's engine related IF you put right amount of oil in, etc, etc...
Hi, there is no opening in valve cover to put oil in,you would have to take hood off. I managed to get at the front glow plug out today, but cannot remove it, the intake manifold is preventing it's removal.I did get the front injector out and looked down,piston had very little carbon on top. I was unable to see cly walls on the front one because the piston is at rhe top.It is Is also in the wayvery hard to get at the glow plugs and injectoes and glow plugs because of the intake manifold I am goingto take it off to get at the other two injectors. I have noticed some shiny something exposed behind to crank pully,like the crank moved forwards.I saw this before trying to move crank nut.I am not sure this nut controls backlash on the crank or not.I am takeing pictures but cannot figure out how to post them.Anyway still waiting for a shop manual to see if transmission and related hydraulic system can be isolated. I had just dug out four out of 10 broken 14 x1.5 bolts that mount fel to the engine or bell housing I cannot tell because tractor has a cuttis cab on it and is also in the way of everything, So bare with my slow posrs you are not talking to a white screen I am here,and thanks for all your advise
/ engine seized or hydraulic lock? #43
Sounds like you have a real handful there. Loader (busted mounting bolts, no less), Curtis cab, old-style engine compartment, etc. Have you popped the starter off yet? That's a likely culprit (jammed Bendix, starter motor itself seized up, etc.). Might save you working on the engine itself.
/ engine seized or hydraulic lock? #44
When you replaced loader bolts if they are to long they will hit the flywheel and not let the engine turn over? kiss start with last thing you did and work backwards.
Great idea I will back them off,still waiting for manual thanks again! You were right, you are a very smart man,and I admire your thougt process. I did buy new bolts and could only get 70 mm long I measured the depth and judged according. I diid not want them to bottom out or use locktight so if they break again I will be able to prick punch them out instead of drilling.I guess I measured to the flywheel without thinking where those through holes went.I know now.Now to put it back together and wait for snow.Thank you so much, you made my holidays, I wish you would send me your adress so I could send you a small gift. Thank you again sir, Peter Will
/ engine seized or hydraulic lock? #47
Rut-roh! If it WAS the loader bolts, sounds like they have forced the crank so hard as to physically move it enough in the block to reveal "polished" areas on the crank pulley. This might have caused problems in other areas like thrust bearings, main seals, or rods.
- Jay
/ engine seized or hydraulic lock? #48
If he can back the bolt out, he should be ok but should check flywheel teeth.This should be something not to forget and maybe should check our bolts.
No, one loader mounting bolt went through the engine casting to bind the flywheel.I had a One inch drive 3 foot breaker on the crank shaft pully nut and could not budge it.This would be a great theif deterrent..and after backing off on the fel belly mounting bolts I could almost turn it by pulling the alternater belt if it did not slip because it is a bit loose.I cannot stress enough to back track as what you. did before the problem occurred. Thank you everyone for you help with my brain fart.
/ engine seized or hydraulic lock? #50
Along with the KISS principle logic needs to be applied as in, what did I change on the tractor since it last ran. In the original post the OP never mentioned replacing bolts. This has been the standard "Goose Chase". :)
Hopefully he didn't do more damage.
Well you did not read any of my other posts I posted.I am sure there are a lot of goose chases.Sometimes it is in front of you amd you cant see it, Sorry for your goose chase. You were of no help to me! Go and be critical of somebody else who needs help.And go ride a goose!
/ engine seized or hydraulic lock? #52
Whoa, hold on Skippy..... I offered you lots of ideas. I was and am not now critical. Experience tends to assist in the search for the error in situations like this. Everyone has offered their experience to you to find the problem. Several, along with me, have said to stop trying to take your tractor apart and look for a simple solution to the problem. You finally found it. We are all happy for you and hope everyone reading this thread learns something. Hang around and you might too. :)
Episode ended, no damage to flywheel, recived a nice manual through Messick's.I needed one anyway. Thanks to all for the help everybody! .And guess what its February here and haven't recived any plowable snow yet.
/ engine seized or hydraulic lock? #54
I agree it may be a simple electrical problem. Disconnect the ground cable from the battery, charge the battery and while it is charging; ensure the ignition is turned off, if a diesel make sure the fuel is turned off and the transmission is in neutral with the wheels blocked. Now you can safely bar the engine over by hand. I want you to manually do it, to minimize the chance of damaging the engine. If you cannot complete two full turns of the crankshaft without locking up, you probably have a head gasket, or injector leakage problem. If you can bar it over as described, clean your battery connections at both ends. Make certain the battery is fully charged and reattach the ground cable. The engine should spin over properly. If not you will have to diagnose the electrical system.
/ engine seized or hydraulic lock? #55
Read posts 44 and 45...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
John Deere 4044M (A60462)
John Deere 4044M...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2006 Lexus GS 300 Sedan (A61574)
2006 Lexus GS 300...
