Price Check 2014 vs 2015 MX5200
/ 2014 vs 2015 MX5200 #21
That 1691lbs number for the LA1065 is for 500mm forward of the lift pin at max height where the loader is the weakest. Lift capacity at 1500mm and 500mm in front of pins is 2319lbs so make sure you are comparing apples to apples.
Here are the tables/graphs from my LA1065 manual.
Luke, those charts really illustrate how much more lift a loader has down low as compared to full height. it is one thing to see figures, but I think the graphic depiction of the lift really shows you what can be done at the various heights, at both the pins and 500mm out. Good on Kubota for actually publishing that data.
/ 2014 vs 2015 MX5200 #22
Yes, and breakout REALLY drops off too.
/ 2014 vs 2015 MX5200 #23
This is a LA1065 loader on an MX5100 my son bought this past Spring, guess they out of the older loaders. Don't know all about those numbers but this is good size scoop of poop, it was very wet too, for a 6' bucket. He spread 15 loads Saturday with the old IH 155 bushel spreader.
/ 2014 vs 2015 MX5200 #24
Obviously the La1065 is a very powerful loader. Poop don't weigh as much as rock, but the specs look very good for that loader. I think it would lift about anything you put in the bucket easily. That was probably the loader that Ted the wildman had on his Kubota in the EA grapple torture test video.
/ 2014 vs 2015 MX5200 #25
You are correct. Never really thought about so I looked it up and a "wet", and this stuff was quite wet, cubic foot of poop weighs about 62 lbs. according to UVM. Wet 1/2" to 2" gravel weighs about 125 lbs. per cubic foot. I know they said the MX5100 was getting light in the rear with the bucket heaped that much. It has loaded tires only, I think he's going to put 2 or 3 sets of wheel weights on it next Spring.
/ 2014 vs 2015 MX5200 #26
I'm surprised at that number too. I checked it against the la844, which came on the previous generation of MXs, and according to Kubota, the 844 is stronger, which doesn't make much sense. I will say that between those two, the MX would get my vote. I'm very pleased with mine so far. Are they pretty similar in terms of features, namely, do both have SSQA, cruise control, and telescoping link arms?
The L doesn't have the telescoping link arms but the other features are the same.
Thanks all for the explanation on the loader. My friend just bought the L4701 and with pallet forks he said the LA765 would not lift a pallet of goat food (2000lbs) out of his truck. He had to offstack 10 bags (500lbs) to lift it. If I go with Kubota I'll get the MX but the loader capacity question was moving it to the bottom of the list behind Mahindra 2555. With the above explanation I'm thinking the MX will lift my pallets of feed so big orange is back to the top.
Comparing Apples to Apples (pivot pin @ 1500mm) The LA765 is 1684lbs vs LA1065 2864lbs
/ 2014 vs 2015 MX5200 #27
Only 1200lbs different!
If u get the MX, load the rears and put 700-1000lbs on the back minimum for loader work.
I may also be looking at wheel weights.
/ 2014 vs 2015 MX5200 #28
A couple more things to add:
Mine with the la844 will not lift pallets of feed out of a semi trailer. We buy 2400lbs of feed and it comes on a heavy 50-60# oak pallet. What I do is back up to the truck and toss about 8-10 50#bags onto whatever implement I have on the three point. This lowers the amount I'm trying to lift and increases my rear ballast. I can personally tell you that the more weight on the back the better. I do have filled 13.6x28 ags, but I wouldn't try to lift that load without at least 800 lbs on the back. 1800 would be better.
If picking up pallets is your only use for the forks, then getting a lighter set will increase your lift capacity. Mine weigh at least 450#, so I could lift another couple hundred pounds of feed with a 250# set of forks. I got heavier ones because they were available on the lot and I don't have to worry about bending them. Also, I've never checked my loader relief valve pressure setting. Many people here have reported that their tractors came from the factory with a relief setting lower than factory spec. Perhaps you can have the dealer check this when you purchase.
Lastly, the telescoping link arms are worth the price difference in themselves. If you only change implements a few times a year, then it won't be as important, but if you're going to be changing them with any frequency at all, you'll really like them. I don't have them and sure wish I did because sometimes I change implements 5-6 times/day (really need another tractor to add to the stable).
/ 2014 vs 2015 MX5200 #29
I tested and adjusted my relief valve a couple months ago. Very easy. I plan on posting a "how to" soon.
/ 2014 vs 2015 MX5200 #30
The reason the new loader looks less powerful is because a SSL coupler is now standard equipment and it moves the pivot point out. The older MX loader is the same spec, but the SSL coupler was not standard so the spec sheet was done with a pin-on bucket. Good for customers to make it standard, but bad for those who shop based on spec sheets.
/ 2014 vs 2015 MX5200 #31
Maybe I missed something but the topic has moved to comparing the L4701 to the MX loader (rather than last generation mx to current mx). But that is an interesting point.
/ 2014 vs 2015 MX5200 #32
L39 speecs for comparision. I suggest larger L1065 loader. Get the 2014 if it has larger loader.
http://www.tractorbynet.com/forums/...ota-l39tlb-access-2.html?posted=1#post4312291
/ 2014 vs 2015 MX5200 #33
I am thinking a bolt on cutting edge.If so,I wouldn't think the aftermarket would be much cheaper as the piece would probably have to be made to order.
Weleded on repalceable Esco teeth on my old cutting edge. I have a new smooth cutting edged also, but use my little tractor for times where I do not want teeth.
/ 2014 vs 2015 MX5200 #34
Took delivery of new mx5200. Received owners manual for tractor but am wondering if I should have also received a manual for the front end loader. There is no information for the loader in the tractor manual.
I took delivery of a MX5200 with LA1065 loader today. Dealer gave me a separate operators manual for each. Also for the bale spear and finish mower.
Does your loader have a bucket level indicator? I was spoiled to one and wondering if it was available.
/ 2014 vs 2015 MX5200 #35
Congrats in the new toy/tool!
The dealor threw in the bucket level indicator when I got mine (they are like $70). It is a flimsy POS. First thing I did was take it off as I knew I would immediately rip it off in brush.
/ 2014 vs 2015 MX5200 #36
Make a heavy duty one:thumbsup:
/ 2014 vs 2015 MX5200 #37
Teir 4 iand cost was the main reason I bought a leftover 2013 Mahindra Max28. Mahindra Teir 4 are less pain than Kubuta with the regen.
/ 2014 vs 2015 MX5200 #38
I think my son paid $65 for the bucket level indicator on the LA1065 loader. I didn't think that was too bad considering the kit came with 2 replacement pins for the loader. No one has torn it off yet. Here's some decent views.
/ 2014 vs 2015 MX5200 #39
Thanks. I'm going to call dealer and see about that. I do a lot of manure work. So knowing that the bucket is level and I'm not digging dirt is important to me.
/ 2014 vs 2015 MX5200 #40
QUOTE]
That is a ridiculously good deal as the pins purchased alone cost more than the kit. Could you measure the Pin Diameters? I may buy just for the pins
2016 Chevrolet Express 2500 Cargo Van (A61568)
2016 Chevrolet...
2019 GENIE S-60XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
2020 Kubota KX057-4 Mini Skid Steer (A61166)
2020 Kubota...
