3 point wood splitter
/ 3 point wood splitter #1
teach
Rhode Island, USA
Question: I have a 21 hsp hydro Kubota b7500, and was wondering if anyone can recommend a 3 pt wood splitter that will run reasonably fast (similar to a stand-alone splitter in the 20-ish ton range)? Also, can a 3 pt splitter be run off the loader's hydro's? I don't have rear remotes. I split about 6 cords a year, but am getting tired of maintaining multiple engines and I am trying to simplify, and tired of people borrowing and beating on my stand-alone.
Thank you in advance for any ideas you might have.
Teach
/ 3 point wood splitter #2
With the flow rates on a B, I think you'd be disappointed in the speed. You might want to look into one where a hydraulic pump is driven off the tractor's PTO. Conceivably, that would allow you to generate flow rates that are not limited by the tractor's hydraulics.
/ 3 point wood splitter #3
Teach
I understand your desire to not maintain so many engines but I might have to start thinking about a second tractor as I have so many thing i can do with the tractor now I need another and great example is powering the wood splitter and bringing the wood to the splitter. It seems like about once every other week I run into situation where it would be really nice to have another tractor. the bottom line is that I would not want to tie up my tractor in splitting the wood.
/ 3 point wood splitter #4
Your tractor only has 7 GPM hydraulic flow. Unless you use a tiny cylinder like a 5 ton it will run painfully slow. You could use a PTO pump which would provide a much faster cycle time.
/ 3 point wood splitter #5
Regen valve will speed up the extend stroke until it needs more power. Similar to the 2 stage pump.but will still return slow.
Pto pump is another option. Can use most of your HP for hydraulics. Where as the onboard pump on your tractor don't use all the tractors hp, or there would be none left for driving around.
Then a pto WITH a regen valve would be the quickest.
None of the options are going to be cheap, since you don't have remotes.
LD1, could I just run a pto pump and plug lines from the pump into the reservoir built into the axle on my splitter? I don't need to move the tractor while running the splitter at the same time. Since I already have a pto pump for my backhoe, I was hoping to be able to also use it for the splitter. Not sure how much of pain that will be to hook up/unhook, but the backhoe is about to come off for the winter anyway (time to start hauling firewood out of the woods).
Thanks for your help.
Teach
/ 3 point wood splitter #7
Yes you can do that. but you need to know how many GPM the pump is to determine if you need more oil capacity than what the splitter currently holds.
/ 3 point wood splitter #8
You would be much better off with a gas powered splitter with respectable cycle times. Very frustrating waiting for a slow cylinder to cycle.
My splitter has a 22gpm pump and is powered by a 10hp HH100 Tecumseh which cycles in 6~7 seconds which makes it very efficient.
I then adapted it to mount on my 3pt hitch which made it very easy to move and place.
I bought my tractor to use but running it at full throttle to operate a splitter (slowly) in my opinion is not a wise use for it.
90cummins
/ 3 point wood splitter #9
Just curious, why "full throttle"?
I use the hydraulics on my JD 790 for my 3-pt splitter at a fast idle. No, it's not fast, but I work alone & i'm not fast either & it works fine for me. HPIM3914.JPG I just added long hoses to hook to the loader bucket connections & tie the joy stick off to the opposite fender.
/ 3 point wood splitter #10
90cummins
IF any of my tractors can't take a steady diet of running for an extended period of time at rated pto speed, i'll call it junk and send it down the road!! That's what tractors are SUPOSE TO be made to do...
On the other hand, I don't run my tractor at pto speed to power my pto powered splitter, because it runs "fast enough" at a lower than pto speed that I don't need to.
BTW, it burns waay less than a gallon of diesel per hr. to run my splitter, that will split ANYTHING I put on the beam, so the cost to run it is very good too...
SR
/ 3 point wood splitter #11
I like the idea of a PTO splitter to get rid of the extra engine to maintain. But I like to position the bucket of my FEL next to the splitter and load the split wood directly into the bucket to cart it off. What do those without an extra tractor do with the split wood to avoid the extra handling?
/ 3 point wood splitter #12
Here is my BX2660 running my pto driven splitter. I run around 1800rpm.
/ 3 point wood splitter #13
I load my firewood into a wagon or trailer, then split right off the wagon...NO lifting, I can roll the big ones right off my wagon onto the splitter beam,
Better yet, I actually cut my firewood OVER my wagon, so I don't have to lift them up onto it!
SR
/ 3 point wood splitter #14
Getting back to the original question, the only 3 point splitter I know of that works well with low hydraulic flow is the PowerHorse 13 ton splitter I have on my JD 2320. I'm not sure if it is still being sold by Northern Tool. It works because it's a small cylinder (hence only 13 ton) and it's a two way splitter so you don't have to wait for the return. It has enough power for everything I split but I avoid the really large rounds because I don't want anything I can't lift.
If you can't deal with the limitations you will need to go to a stand alone or a PTO splitter.
/ 3 point wood splitter #15
I have a splitter that I ran off my BX22. It ran just fine for me and had a cycle time about 10 seconds +\-. That was more than fast enough for me to have to move and pick up logs. I believe if is a 18 ton. Mine ran off the back hoe loop. I imagine you could run yours off the front loader valve with some longer hoses. ..6 cord a year would be a cake walk.
/ 3 point wood splitter #16
Teach
Ha, once you get the 3pt splitter, they will just want to borrow your tractor and the splitter!!!! :laughing:
/ 3 point wood splitter #17
Not happening!!!
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
199 (A64278)
199 (A64278)
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Turtle Statue (A64557)
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
