M7060 weight with BH?
/ M7060 weight with BH? #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
I think it's way too much tractor for me but a dealer has one with 300 hrs and is offering a deal I might have to find a reason to jump on but can't for the life of me find any reliable info on the specs of the M4011 BH.
A for sure deal breaker is if it's not going to fit on my current trailer etc. which I think it's going to bust. Anyone know the weight of tractor with FEL and BH?
Thanks
/ M7060 weight with BH? #2
I know the hoe on a BX-25 is 700 lbs. I would say triple that for the M hoe and add another 800-1000 for the fel.
/ M7060 weight with BH? #3
Not exactly the same, but close, actual weight on a M7040SU with LA1153 loader/bucket, cast wheels 8860lb.
/ M7060 weight with BH? #4
how much do you need a hoe? lots of weight on that.
Thanks, dealer is saying just under #9k.
You have the 7040 I assume, like it? Would you go that big again and what do you do with it?
All the time:licking:
I was actually looking at a Medium-ish excavator to get some stumps out and dig a pond but looking long term I think a bigger tractor will do better a lot more work for me and I can actually justify purchasing it so I'll just rent an excavator/dump truck for a weekend to put in the pond.
/ M7060 weight with BH? #6
So far so good and quite happy, haven't had it long. Used on a beef farm (jobs will be haying, loader work etc) Went that size since wanted more power and traction compared to the 7520lb 2wd 40HP utility we still have.
/ M7060 weight with BH? #8
My M7040 HDC-1 with cast wheels,liquid ballast in rear tires & LA1153/rd bale spear weighs 8888 actual #s
Tractor was 8260lb with just loader arms (no bucket), so interesting how loaded tires and bale spear only add up for 600lb. It does have metric R-1W tires, so I wonder if those weigh a lot more than the normal rubber. The SU should be a little lighter than a straight 7040(?). Considering the sales lit said the M7040SUHD was like 4600lb dry (I am assuming no fluids or wheels!)
/ M7060 weight with BH? #9
I think difference in weight of R-1 vs R-4 tires will depend a lot on their size. My tractor has 16.9X30 rears & 9.5X24 frts. According to Miller Tires my rears weigh 183#s each & frts weigh 80#s each
/ M7060 weight with BH? #10
You have the sizes shown on the sales lit, It's on R-1W Radials, 420/85R28 and 360/70R20 Rears are 204lb each and Fronts 110lb each, but that only equals 100lb more ?
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
