Which pole saw??
/ Which pole saw?? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
Looking to buy (maybe) a pole saw. Gas, probably adjustable length, $500-$600 ish price range I guess. Brand names I'm thinking are Stihl, Echo, and Husqvarna in that order probably as those are the ones I'm familiar with. I've 2 Stihl chainsaws, and one Echo. Never owned a Husqvarna but I've read some good things about them. Definitely open to others as well
I'm early in my search and would love to hear what you have and how you like it. All ears right now..
/ Which pole saw?? #2
I have a 30' Stihl PP800 manual, aluminum pole saw. I have used gas powered pole saws with chain cutters. The PP800 is easier to use and it has much more 'reach'.
PP800 is an entirely different tool from fiberglass handled pole saws with thin, flexing blades, sold by Loews and Home Depot.
About $260, plus tax.
VIDEO: https://www.youtube.com/watch?v=SCbeRPu5MIA
STIHL LINK: PROFESSIONAL POLE SAWS ------ Read the consumer reviews.
/ Which pole saw?? #3
That guy grew a beard by the time he cut that branch off.:)
/ Which pole saw?? #4
Whether you’re pruning low-hanging branches or trimming up high, cutting performance is key. The gasoline-powered STIHL HT 101 allows you to quickly adjust between 7’6” and 11’6” shaft lengths to bring down those hard-to-reach branches. Even at full extension, this pruner is easy to control and feels well-balanced in hand. If your job demands height versatility, this pruner delivers a great price-to-performance ratio. And if you have a great deal of pruning to do, take a look at our HT Carrier System, designed to transfer the weight from your arms to your shoulders.
Great saw....paid $500 2 yrs. ago. Very easy to use and maintain and well balanced.
/ Which pole saw?? #5
This past spring I did my comparison. I went with a Stihl HT-101. I looked at the brands you listed. Would repeat the purchase.
The HT-131 is the same machine with larger displacement. But it's a 12" bar and safety chain so I have never found torque or HP to be a limiting factor (this is what I had read in reviews). Basically the 131 is more expensive and heavier without any benifit.
/ Which pole saw?? #6
How much does that one weigh?
/ Which pole saw?? #7
16.3 pounds, with cutting attachment. 17.2 for the HT 131.
Object moved
They're pretty heavy, but they're designed for heavy duty use, like from pro arborists, etc.
I have an Echo pole pruner with both a 10" and 12" bar. The 10" is the standard setup. It is on a 'multi tool' engine/split shaft, so it is not just a pole pruner. It is considerably lighter than the Stihls, (12-15 pound range, I'd guess), and in this situation the lighter unit works for me for several reasons: it's lighter and less fatiguing, it is for multiple uses, it costs less overall being able to have a hedge trimmer, weed eater, pole pruner and tiller in one tool. YMMV.
Echo are good tools, as are Stihl. I own both for different reasons/uses.
/ Which pole saw?? #8
Typically you hang it on a shoulder sling or harness and the drive unit balances much of the weight of the pole. But weight is an issue eventuality.
Ive previously used big box store gas power pole pruners and the 101 is not in the same class.
/ Which pole saw?? #9
Not sure what you're going to be using your saw for but......a few years ago......I bought a Remington electric pole saw to do some light trimming around my shop. I have a couple of Stihl chain saws for wood cutting but needed something I could use while standing on a 26 ft. ladder. Over the years......that Remington has trimmed thousands of branches. I have used it down the driveway with a small camping generator. The cord is annoying but for under a hundred bucks......that little saw has held up well. If it broke tomorrow.......I'd toss it and buy another. Good luck.
Remington RM1025SPS 10 in. 8-Amp 2-in-1 Electric Chainsaw-Ranger - The Home Depot
/ Which pole saw?? #10
I have both Stihl and Echo chainsaws. My dealer sells both and at first, I went there to buy Stihl because I thought they where the best ones out there. I had Husqvarna and when it was new, it was fine, but it dies rather quickly and I hated trying to get it started before it finally quit completely. I first learned about Echo from my Stihl dealer when I was looking for a new weed eater. He had several Stihl's to choose from and when I asked him about which was better, he told me that for the same money, I could get an Echo with a bigger motor and gear box. Or for less money, the same sized motor and a bigger gear box. Having read good things about Echo, I gave it a try and loved it!!! When I went back to buy a pole saw, I was already leaning towards the Echo brand because you get more power and stronger gears for the same money as Stihl. And that is exactly what I did. I never had a Stihl pole saw, so all I can compare it to is my Stihl chainsaws. It starts easier!!!!! It has plenty of power, but you really have to wear the strap to support the weigh because it gets heavy after awhile. You will especially notice it on your forearms!!!
Oil mixture is different between Stihl and Echo, so if you already have one brand, it might be worthwhile sticking with that brand just to avoid having to have two fuel cans. I wrote on my with a magic marker to tell them apart. One gallon gas cans are cheap, so it's not that big of a deal. It just gets confusing if I have them all out, plus two gas cans take up twice as much space on my shelf.
/ Which pole saw?? #11
I forgot to mention the somewhat better starting on Echo equipment. I too have found it to be the case. Stihl equipment is more like a race car vs. a street car- it's just more demanding, and sometimes a pain.
I don't do anything but one mix of E free high test gas and Stihl's Ultra premix oil for all my equipment that takes a mix, regardless of brand and age.
It is more important to have the best premix oil and best non-E gas present in the tank for all these tools.
Yes, ten years ago they still had various mixture ratios for gas/oil, but now, IMHO, one and done. I've had no issues doing this one mix in saws from the 1980's right up to present day ones, plus weed eaters, etc. YMMV, but not likely....
/ Which pole saw?? #12
For older two-stroke equipment the ratio was 40:1.
I am pretty sure all new equipment specs a ratio of 50:1.
Some Stihl equipment specs 89 octane gasoline, rather than 87 octane.
Absolutely no problems associated with starting a PP800.
/ Which pole saw?? #13
I have the 7' Professional Stihl with the 40cc power head and 14" bar. Weighs a tad under 15#, I guess and has great power. Easy to start. I've used it a lot over the past 5 or 6 years with no trouble. I have the harness, but have never used that Its only flaw that I see is the low kick-back chain which slows the cutting rate a little, I would prefer professional grade chain and its not like kick back is going to be problem with a 7' pole between operator and blade. I find that Husqvarna equipment is very good too as long as you stick with their premium or professional grade; which is what I do with Stihl too.
prs
/ Which pole saw?? #14
I have the Husqvarna professional adjustable pole saw. It works great and I got it to raise the canopy around our house. We have 30 + big trees and the saw makes short work of the cutting. Still have to carry the limbs away which takes much longer. The only trouble I have had is when a squirrel chewed through the gas tank. Epoxy fixed that problem. i wear the sling to hold it and it works fine for me. Turned out to be much cheaper than the local tree service which we did once. I use Startron in the oil-gas mixture and have used a Husqvarna 450 chain saw as well for yearly firewood and tree cleanup. Good equipment!
/ Which pole saw?? #15
I have saws needing 16:1, 32:1, 40:1, and 50:1. :(
Bruce
/ Which pole saw?? #16
For those of you who like Echo, they liked Shindaiwa so much, they bought the company a few years back.
Really good stuff.
/ Which pole saw?? #17
They can all run on the latest 50:1 semi-synthetic JASO-FD oil, which has been
the standard for nearly 20y. You will have to retune them a bit. The newest
oils have the latest anti-friction anti-smoke technology, which was unknown (or not
commonly available) in the old days of 32:1 mixes. As far back as the 60s, you could use
16:1 ratio with motor oil, or buy special oil from the manufacturer to go as much as 40:1.
As for the pole saws, I have used them from Stihl and Echo, but I found them too heavy,
and now use a cheapo B&D 18V electric. I wonder if the big brands have Li-ion electric?
That would be even better, IMO.
I just got a reciprocating pole saw attachment to try out. No oil required. Need to get
a new blade before I try it.
/ Which pole saw?? #18
If you don't need quite the reach or a dedicated pole saw, the Stihl Kombi is a good alternative. I wouldn't go less than the 110 though.
/ Which pole saw?? #19
I opted for the Stihl Ht-131.
I recently trimmed a few thousand feet of treeline at maximum pole extension. The saw never missed a beat - but it does get heavy. The Stihl harness was not impressive, so I bought this one instead.
Home
/ Which pole saw?? #20
I bought the Stihl HT131 last year mainly because I have a good Stihl dealer about 5 miles away. It is heavy but it is very easy to start and the power / performance is excellent. It has proven to be an invaluable tool for me.
2017 Hino 155 16ft. Box Truck (A61573)
2017 Hino 155...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2003 ANDERSON 100" X 28' GOOSENECK FLATBED TRAILER (A64276)
2003 ANDERSON 100"...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
