My NEW Case 530 utility tractor
/ My NEW Case 530 utility tractor #1
Walker1
Phoenix, Az
Case 530
Some years ago I sold the '48 Ford 8N that I used around my house. I had it up at my place in the mountains, but it was not heavy enough to do work up there. Also with the well worn motor, it barely had enough guts to pull itself up the mountain, much less a load of dirt. I also sold my Cat forklift and bought a Case 1845 skid steer thinking that would act as a forklift and front loader, but found out they make terrible lifts for guys working alone. I recently sold the skidder as well.
I was looking for an early Case 580 when I ran across this 530 with a loader and gannon for a reasonable price. The rear 3pt wouldn't lift, and the fluids were milky. After I got it back to the shop, I changed the fluids and filters, and rebuild the lift cover piston. Had to hone the cylinder because of a rust ring, but it holds like a rock now.
I picked up two new rear 14.9 24 Alliance tires, for $295 each, and am planning on putting those on in the morning.
I have a lot of slightly weepy seals on the loader, and one leak on the front pump. I bought a seal for the front pump, as it is only slightly weepy while running, and drips after being shut off. I thought I would try the seal first. If it still leaks afterward I will just put in a new pump. The loader bucket needs a new cutting edge welded in as well. I plan on putting on a reversible bolt on edge as well.
It was difficult to keep it running initially, as the crud in the tank kept blocking the hole into the sediment bowl. I drained out the old fuel, and installed a screen onto the inlet side of the sediment bowl, and replaced the missing screen in the top of the bowl. I had to take apart the carb and clean some dirt out of that, as the needle and seat were sticking. I will likely need to replace those as they seem to stick closed from time to time now, but is at least serviceable.
One of the brakes was shot, and had been taken apart. I ordered new bands and balls and got that working. Still need to replace the side linings, but both brakes function now.
The clutch pedal had broken and the PO welded on a car pedal the the stub. It works, but doesn't have the right articulation. I will look for a pedal for it, or just forge a new piece with the right curvature.
I need to build a seat pad for it as both of the pads are missing. The rubber seat springs are shot as well, but those can wait.
The Gannon has been abused and will need two new cutting edges, as well as 8 rippers. I had 4 from my last tractor, so I put those in. The latch mechanism doesn't work, as it is bent up inside. I should be able to make it function again with minimal effort though. The linkages that control the ripper bar are all shot, so I will need to make some new pieces there.
By the end of winter I should have it back into respectable shape and be able to run it up to the mountains to maintain my road and building pad.
Got the new rear tires on. It rides much better.
/ My NEW Case 530 utility tractor #3
Nice..!!
And so starts my "restoration"
After having pulled the front pump off only to find it had PO disease and was not repairable, I did what I generally try to do on these projects, and clean up the affected area and make any other repairs so I don't have to tear it apart again.
I tried to pull the splined shaft, so I could install a new fan belt. It wouldn't budge, so I had to pull off the adapter. The bolts wouldn't come all the way out because of the radiator mount. I pulled the hood, and the fan, and the radiator and mount. Then got the adapter off and knocked out the shaft, blasted and painted it all. After several pressure washings and digging through the muck I got the front end cleaned up. I went ahead and painted the area. It is all ready for the new pump, which should arrive in a week.
I will be waiting impatiently for the new pump to arrive. I had been enjoying driving the mile up to get the mail, and generally toying around with the tractor.
The pump came today, so I was able to get my tractor moving again. Since the grill and front bumper were off, I sandblasted them and gave them a coat of paint. Since I was painting, I also shot the front wheels, and removed the seat and blasted and painted that as well. I made a couple of patterns for the seat to make a couple of cushions.
Also, last week I pulled my LH lift link and repaired that. The leveling box was pretty badly cobbled, so there is no saving it. I have one for a Massey 245 on the way, hopefully it will fit without too much work.
/ My NEW Case 530 utility tractor #6
Nice job bring her back to life. I hope she gives you years of postal service.
/ My NEW Case 530 utility tractor #7
Well, in looking around the forum, I found that you had started a thread here. I'm really enjoying your thread, and specifically the progress and descriptions and the pictures. A picture is worth a thousand words. It looks like my pump is the same as yours and you are doing a very sanitary job of cleaning, painting, and replacing parts. Your overall picture of the tractor/loader just looks great! Hope your Gannon box replacement goes well.
/ My NEW Case 530 utility tractor #8
Can't go wrong with the Gannon BB. If you get the fancy to do so there's a thread on here somewhere of a member converting the manual scarifier to hydraulic. I converted mine and it works great.
Nice work on the old tractor. I always liked the personality of the older Case tractors!!!
I have been considering doing just that. I need to finish rebuilding the blade mount and box sides first. If you have any pictures or measurements of the sides I would appreciate seeing them.
This is the box blade I have. There is a name on the side, just not enough for me to make out. The linkage is not like the other Gannon blades I have seen. I have been trying to determine how much of the sides are missing, so I clamped a straight edge along the top bevel of the brand new 6" blades. There is at least an inch and a half missing from the bottom at the blade mount, as it is worn down to the bolt holes. I have considered cutting out the angled blade mount for rework, as it would make welding and punching new holes easier.
Btw, I searched for the hydraulic ripper conversion and couldn't find anything on it. If you get a chance would you post a link? No big hurry, lots of irons in the fire I need to get out first.
Thanks,
/ My NEW Case 530 utility tractor #13
Well hopefully it turns out to be a labor of love as bringing a old worn machine back to life can be really rewarding, and expensive.
I managed to o get my brake and clutch pedal the issues mostly solved today. The brake pedal shaft was very stiff and would cause the left side brake to hang up. When I would push the clutch pedal it would drag the brake shaft with it, then the brake would not release all the way as well. The clutch pedal had broken at some point and the PO welded a car brake pedal to the stub. It was a cobbled mess. I bought a used clutch pedal and that came in the mail yesterday.
I pulled the brake actuator lever off the left side, then the clutch pedal. I was able to get the shaft to turn freely, then flooded the thing with grease. I cleaned up the shaft that was sticking out and reinstalled the new pedal and brake actuator. I had to remake the clutch pedal rod as it was a mess as well. I will need to make a new one, but this will do until I can order a clevis fork and some small bushings to take up the slack. The new clutch pedal has a fair amount of play in the pivot point, and then old one had none. I think I will end up boring out the new one and pressing in a bushing there as well. It works decent now, and my brake pedals return, so the major problem is solved.
The picture s of the clutch pedal from underneath the tractor.
/ My NEW Case 530 utility tractor #15
Good stuff. You sound like me. I can't stand things like that...... Don't understand why any owner would let it get to that point. If my pedals/levers/knobs don't work properly I'm tearing them apart to find out why.
Do you have a tractor salvage company that you buy parts from??
Just managed to find some online and through some emails. I got the clutch pedal and a power beyond fitting from JC Marleau. Super nice guy, I would recommend him to anybody.
/ My NEW Case 530 utility tractor #17
You're right, JC Marleau is a real nice man. I bought a manifold heater core and a instrument cluster form him, he's lives up in Canada as I remember. I sent him some pictures and we exchanged a couple of emails too.
Here are a couple of pictures of my brake and clutch sides of my machine:
Brake side with the new emergency brake handle and rod that I fabricated.
Clutch side and new rod and springs.
I looked at your picture and really appreciate what you're going through. Cheers!
/ My NEW Case 530 utility tractor #18
Hello case IH guys I am DJ and I recently acquired a new/ antique case model D or I think it's a orchard model maybe so I think I'm in the right thread to chat anyone want to?
/ My NEW Case 530 utility tractor #19
I would suggest starting a new thread with the tractor make/model in the title? Most members of TBN search "New Posts" or "Today's Posts" for anything new each time they log on. Your thread will show up and if anyone is interested in that tractor they'll join in. Another tip is to include pictures. The fact that you have added pictures shows up in the thread info as a paperclip. This interests a lot of readers and they'll check in just to see your pics.
Looking good Stans1. The parking brake rig is on my list to repair, mine is pretty mangled.
Today I got my box scraper repairs done. I drew up some side plate patches and cut them out today, then welded them on. Then I drew up a 72" x 1 1/2" rectangle with 3/4" half circles along one edge. Then I welded it to the bottom of the blade mount to replace the worn away section.
I'll try to get some better pictures tomorrow after I take it off the table and put it back on the tractor.
