work platform on truss boom
/ work platform on truss boom #42
What do those units do in regard to hydraulic failure?
Seems like an orifice on each cylinder would protect-ish against hose failure. Of course, not against cylinder failure.
It's called a hydraulic fuse. It is like a check valve with the spring holding the valve OPEN, untill excesive flow causes the valve to close and then the pressure differance keeps it closed. It may leak down slowly when tripped.
/ work platform on truss boom #44
Dont worry, i didnt post this here to ask for anyones approval, to take well assessed risks that only involve myself and no third parties. ;)
By that statement I assume you are not married and have no kids or old parents that depend on you.
/ work platform on truss boom #45
My washer hoses have (supposedly) protection against bursting............where they shut off automatically. Maybe something like that?
Just for discussion purposes....
I know nothing specific to man-lifts, but working on other lifting / overhead hydraulic equipment I have seen a few forms of safeties involved.
some use an oriface to control flow / speed and let the item down at set speed.
Another way is called a "velocity fuse" -- sort of like a check valve with a spring holding it open until the flow through it is strong enough to shut down. So a blown hose will allow a tiny burst of free flow out of the port, and nearly instantly the valve is forced shut by the weight against it and stops the movement.
Lots of stuff these days use a pilot operated check valves or counterbalance valves. They are essentially always closed / holding until you apply pressure from your hoses. The pilot circuit pushes the check / balance adjustment open to allow it to move.
/ work platform on truss boom #46
I built a work platform for my loader bucket from wood last summer. When I got it where I was going to work I put a 4 x 4 under the bucket so the hydraulics wouldn't leak down, and for safety. Very simple and effective.
/ work platform on truss boom #47
Cranes, boom lift and material handlers have pretty sophisticated hydraulics where a simple hose failure won't lead to a uncontrolled boom lowering. That is not the case with a simple ag tractor.
Read up.
https://www.worksafe.qld.gov.au/__data/assets/pdf_file/0017/83222/earthmoving_burstprotection.pdf
Its good to hear opposing viewpoints. Some people can do things others cannot. I am 57 and have been somewhat of a risk taker all my life. My dad taught me. His saying was always "Piss on them dirty bastards, we'll build it ourselves". It has worked out well for me. I still have all my fingers, and can do almost anything I could do when I was 17. I know I have saved a lot of money doing, and building things myself. I like it, I feel good about it and my instincts have always served me well. I always appreciate someone who has the ability and courage to do things. It would be a boring world indeed if no one had the spirit to take a chance.
It, in my opinion, is much safer than teetering around on a ladder leaned against a tree with a chain saw in hand.......which I have done on numerous occasions.
Tim
/ work platform on truss boom #48
Tim
It’s got nothing to do with not wanting to do things ourselves. It’s simply a horribly designed contraption. It’s actually designed in such a way that it WILL fail if used with much regularity. It’s not even a question. If it wasn’t built in such a way that it’s constantly trying to tear itself apart due to simple gravity, no one would have said much.
/ work platform on truss boom #49
That's fine. Except that there are some folks on this forum now cogitating on building their own boom lift loader attachment out of wood and using baling wire to fasten it to their bucket. Don't laugh. I once put a 22' ladder into my fully raised bucket in order to free up a flag pole pulley up on top. When I got there, the pole bent over about 10 ft from a vertical position. After that, I rented a boomlift and found it so much more comfortable, I bought a used one. Worth ever penny. As is usually the case for me, once you have such a tool, the additional uses start lining up. Best one is painting a house or barn. Lateral movement plus extension plus an airless sprayer gets the job done in record time. Hope you know your limits one yours Renze, Its a great project. Best condition would be if you had a second person controlling the hydraulics from the ground, or do you have a rope or cable system to adjust the mechanism? The only other thing I would suggest is that you test it with some dead-weight to 'certify' that its won't break or tip over at max outreach with 400kg in it. You know, for that warm and fuzzy feeling.
/ work platform on truss boom #50
I agree with you totally, bailing wire is great stuff. Bailing is much better than duct tape. You can build anything with bailing wire. My dad could fix a flat tire with bailing wire. In my opinion bailing wire should take first place over the wheel for man's greatest invention.
As far as building it out of wood, I could do that. Ships have sailed around the world made of wood, so I'm sure I could get 20 feet in the air with it. However bailing wire would not be my first choice to fasten it all together.
/ work platform on truss boom #51
On my JLG, there is a tap into the hydraulic lift line which feeds the work platform pitch angle. The pitch cylinder is sized such that a horizontal work platform position is maintained no matter what the elevation. Mine also has a yaw angle rotator so that I can square up the platform angle with the wall of a building or sneak around a limb as necessary.
As long as you are comfortable with your lift, one or both of these features could be added. I'd also suggest adding some baseboards aound the base of the platform. Sometimes you have tools and cans of gas/oil/paint, etc. that you don't want to roll overboard.
Yes, we did add a baseboard just above the floor. I needed that when my brother leaned me out of reach and the relief valve blew over, dropping me down 3 meters at a velocity that gave me time to stop the chainsaw, put it behind the baseboard and hold on to the rail. Unless you try to reach too far by putting the boom horizontal, being in the bucket with the boom 60 degrees up, while driving, the boom lift feels more secure than the commercial lifts i have used professionally, because the construction is stiffer (though more labour intensive to build) than commercial booms made of single rectangular tubing.
As said, hydraulically the critical point is at ground level with the boom flat on the ground, when the depth of fall is little (designed that way) Once upright it is very stable, especially with the tractor on duals for a wider stance.
/ work platform on truss boom #53
It would be so simple and cheap to make this lift safer, it just doesnt make sense to me not to do it. Three obvious methods are , orifce fitting, flow control and counter balance valves. Orfices would be the cheapest method. Simply weldup a fitting and drill a hole in it to control oil flow. Problem with this method is that altho you can control the flow of oil out of the cyl, if a hose blows, its still going to fall, only in a semi control method and speed of extend is also effected. If you choose to use a flow control in a meter out arrangement, you have adjustability in the rate of fall, but its still going to fall if a hose blows, By also having a check valve bypass, the extend speed can be wide open. Third method would be thru the use of a counter balance valve. Using this method, it would actually take a set amount of hydraulic pressure to make the boom fall. This pressure is adjustable so you can control speed of fall in event of hose failure, have full speed retraction under normal situations, and has a checkvalve bypass that allows full speed extention. A good counter balance valve would cost around $100 so it just dont make sense to take chances with ones health or life.
/ work platform on truss boom #54
I agree with you totally, bailing wire is great stuff. Bailing is much better than duct tape. You can build anything with bailing wire. My dad could fix a flat tire with bailing wire. In my opinion bailing wire should take first place over the wheel for man's greatest invention. As far as building it out of wood, I could do that. Ships have sailed around the world made of wood, so I'm sure I could get 20 feet in the air with it. However bailing wire would not be my first choice to fasten it all together.
I for one, appreciate your humor! Thanks for the chuckle!
/ work platform on truss boom #55
Muddstopper,
I've had problems with jerkiness when lowering weight with a counterbalance valve. Do you know of a type or brand that works smoothly? Thanks.
/ work platform on truss boom #56
A counter balance valve works very much like a relief valve, except the CBV will have a check valve bypass to allow oil free flow in one direction. It keeps oil from return until a set pressure value is met. Jerkyness could be a result of having the CBV pressure values set to high or having a valve with to high a cracking pressure. Cracking pressure being the amount of pressure needed to start letting oil bypass at a restricted flow rate. As pressure builds, the valve will continue to open until it reaches a full flow letting all oil pass thru the valve. There are more than one type of CBV. The common type is internally load sensing. By internal sensing, it is actually checking pressure between the actuator and the return. A externally sensing CBV will check for pressure on the inlet using a pilot port. If I had a CBV acting jerky, I would try adjusting the pressure settings first to see if that helps. Your settings should be just high enough to control the loads being suspended. If you only need 500psi to support a load, and the valve is set at 1000psi, then the valve is going to be opening and closeing as pressure rises and falls.
Using flow controls is another valid option. Usually only one flow control is used and it is installed to control flow at the outlet side of the actuator, called metering out. You can also install a second Flow control at the inlet to control how much fluid is entering the cylinder, called metering in. Because of the base end and rod end of a cyl have different surface areas. using two flow control allows adjustment of both the flow IN as well as OUT to make the cyl extend and retract at the same speed in either direction. Again, not all flow controls are created equal. A plain flow control isnt a very good flow control, as the pressure differential changes at the inlet and outlet side of the FCV, the flow rate will actually change. A more accurate FCV to use would be one that is also pressure compenstated. There are many flavors of PCFCV, and they are internal as well as external sensing types.
TITAN 84RAKEV2 - 84" HYD LOG GRAPPLE (A64277)
TITAN 84RAKEV2 -...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
1992 Jeep Cherokee (MPV), VIN # 1J4FJ78S6NL230132 (A65563)
1992 Jeep Cherokee...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2001 Ford F-550 Truck, VIN # 1FDAW56F81EC40182 (A65563)
2001 Ford F-550...
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
