Need Advice on a Oliver 60
/ Need Advice on a Oliver 60 #1
SuperA
Shawanagunk NY
FORD 4110 LCG , International 300 Utility, Farmall Super A, Farmall Cub
01414_fIXg1bnwcxU_600x450.jpg00202_7cbvEtYGX6E_600x450.jpgI have an opportunity to pick up a 1940's, Not sure of exact year, Oliver 60 Tractor... Looks Pretty Clean, Runs Good, Everything Works... Price is $1,500... I Know NOTHING about Oliver's but this sounds like a Great Deal to me.
Any Input or advice & opinions of these tractors would be greatly appreciated. Any Problems they are known for or things to check out etc...Thanks, DanO'
/ Need Advice on a Oliver 60 #2
Steal of a deal, it seems, going by the pictures.
Strange tread on right rear tire... neat!
/ Need Advice on a Oliver 60 #5
That price is very reasonable. I have not heard of any weak points on these machines.
/ Need Advice on a Oliver 60 #6
I don't know anything about Oliver's but it looks like a nice tractor!
/ Need Advice on a Oliver 60 #7
I'm not certain but I believe the oliver 60 is strictly a pulling tractor. Pretty much no 3 point or rear PTO (I'm not certain though).
That pretty much limits you to running ground driven equipment trailer implements which if you are in the right area there are still plenty of them around and usually extremely cheap. Some trailer implements would be trip plow, manure spreader, trailer sickle mower, hay rake, and other type implements.
It's definitely a nice tractor for the price the thing looks like the only time it has spent outside is maybe at tractor shows.
/ Need Advice on a Oliver 60 #8
There appears to be a PTO shaft in the last of the OP's photos.
Steve
/ Need Advice on a Oliver 60 #9
Steve
So there is. I didn't even see that pic I only looked at the first two. Definitely a PTO you are correct. thanks for the correction:thumbsup:
/ Need Advice on a Oliver 60 #10
View attachment 447925View attachment 447924I have an opportunity to pick up a 1940's, Not sure of exact year, Oliver 60 Tractor... Looks Pretty Clean, Runs Good, Everything Works... Price is $1,500... I Know NOTHING about Oliver's but this sounds like a Great Deal to me.
Here are some Pics...View attachment 447923
Here's a photo of my 1945 Oliver 60. Paid $2250 for it about 5 years ago.
Had to reline the brake shoes due to leaking seals. Not a difficult job. The 60 is row crop tractor with bull gears (rear drive gears that are arranged horizontally rather than vertically).
The brakes are located behind the covers forward of the rear axles. Removal was something of a chore since the adjusters were rusted. Otherwise the job was easy. Used brake lining stock from McMaster Carr.
I sold it late last year. If I would have kept the 60, I would have replace all the electrical wiring (pretty standard for 60+ year old tractors).
I also owned a 1951 Farmall Super A.
Good luck and enjoy your 60.
/ Need Advice on a Oliver 60 #11
Oliver has a good history and are a solid tractor . I grew up with 2 Super 88 diesels . When they finally wore out , Dad and Uncle Bob bought a brand new 4010 diesel JD . What a day when that was delivered ! That rr tire is what was called a closed tread . Popular when rubber became available . Goodyear , Firestone , not sure . Enjoy !
/ Need Advice on a Oliver 60 #12
While it does not have 3-pt, it does have a mechanical lift which was used for front mounted row crop attachments. We had one when I was a kid which was either a '41 or early post-war. It was a solid tractor, used mostly for hay rake and baler (not PTO powered) pulling and general seed bed preparation.
/ Need Advice on a Oliver 60 #13
I owned a Oliver Super 55 for many years , had a back blade and a Lorenz three point snow blower for it. It was a solid tractor and never let me down with the tasks i had for it.
DevilDig
/ Need Advice on a Oliver 60 #14
careful of slopes & abrupt turns on that style tractor. otherwise, nice machine.
/ Need Advice on a Oliver 60 #15
Cool tractor! I've always loved Oliver styling...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
