DIY tractor weights ideas
   / DIY tractor weights ideas #21
overszd:
W/W fluid is not completely environmental friendly, as it does contain methanol.
Animals will not lick W/W fluid though, as they will with sweet ethylene glycol (automotive anti-freeze). Automotive anti-freeze WILL KILL animals (dogs - cats - farm animals, etc.)!
I've heard this so many times. Can anyone document the death of a dog/cat from licking anti-freeze??? Not arguing. Just asking for evidence. Often heard it, never documented it. My Dog is my best friend. He's wayyyyyyy too smart to lick anti-freeze. :)
My pets might drink it if you caged them with that as their only source of liquid for a few days....
   / DIY tractor weights ideas #22
Yup, neighbors dog. Small puddle on the driveway. Big dog dead after several horrible days.
   / DIY tractor weights ideas #23
I heard that they add something to make it taste bad now. But without it, it tastes sweet. I know, I tasted it.
It kills by damaging the kidneys IIRC.
The treatment is ethyl alcohol.
   / DIY tractor weights ideas #24
Wow. My dogs are around anti-freeze all the time. Spills on the floor, pans full of it. Haven't even saw them glance at it, let alone drink it. Sorry for the neighbors loss.
   / DIY tractor weights ideas #25
That was probably 20yrs ago. Maybe there's an additive now as suggested.... Or the dog was real dumb.
BEET JUICE is the answer here that wont KILL..
   / DIY tractor weights ideas #27
It is the toxin ethylene glycol that makes antifreeze lethal. Because of this, dogs will consume great quantities of ethylene glycol before being repulsed by its aftertaste. By then, it is too late. It does not take a significant amount of ethylene glycol to cause fatal damage to the system; less than three ounces (or 88 ml) of antifreeze is sufficient to poison a medium-sized dog. Antifreeze poisoning affects the brain, liver, and kidneys.
Ethylene glycol is also found in engine coolant and hydraulic brake fluids.
The U.S. Food and Drug Administration has labeled propylene glycol safe and it is now used for antifreeze. Look for antifreeze with this ingredient instead, to keep your pet safer from accidental poisoning.
From Antifreeze Poisoning in Dogs
Sent from my SAMSUNG-SM-G890A using TractorByNet
   / DIY tractor weights ideas #29
   / DIY tractor weights ideas #32
Yeah, that's what we are referring to as "Beet Juice".
My Brother had it in all four tires on his Kubota L3240. Only thing I saw wrong was you had to keep the front tires at a pretty high PSI or the juice would seep out between the tire and rim.
Thanks ovrezd! since I just have a 10' light trailer I cant take it in - I have to buy the stuff to do it myself.
   / DIY tractor weights ideas #34
Yep. Loaded the rears on my M9540 in my shop. Pumped 180 gallons of fluid in them. Took a couple hours to do but saved me a ton of money.
   / DIY tractor weights ideas #35
I get used antifreeze from small garages. They usually have drums of the stuff and are usually quite willing to give it away.
   / DIY tractor weights ideas #36
The smartest dog I ever had was maybe 2 years old at the time and was drawn like flies to cowpies when I left a pan of antifreeze unguarded for 5 minutes. I caught him with his mug in it and rushed him to the vet.
Vet gave him an IV of Everclear which I calculated to be the equivalent of my taking 6 oz of 100 proof vodka on an empty stomach all in one swallow. [The ethanol-which is what Everclear is-prevents the production of toxic metabolites which result in the formation of calcium oxalate crystals in the kidneys .] The crystals cause kidney damage/failure and death within a very few days. Works the same way in humans except that humans have access to kidney dialysis.
Dog stood there for maybe a minute following the IV and then just folded over like a drunk falling off a barstool. Kept giving him the Everclear plus IV Valium several X daily for a couple of days to prevent the seizures which are a side effect of the ethylene glycol metabolites, then slowly brought him out of the drug stupor and he was fine. Lived to almost 13. Vet said if I had not gotten him to the clinic within an hour he probably wouldn't have made it.
MORAL: NEVER be a moron like I was and leave ANY ethylene glycol-based antifreeze where an animal can find it. This means even what looks like a minor leak on the driveway. ALWAYS rinse spills immediately with a lot of water. Takes only a couple of teaspoons to kill a cat or dog. It has a sweet taste which is why so many animals are attracted.
BACK TO TOPIC:
I just finished putting 76 gallons of -20F w/w fluid in my 13.6-24 rear tires on my old Case 530CK hoe. Dealer wanted ~ $350 to put calcium chloride in 'em and I would have had to haul the beast 10 miles each way. The "beet juice" was even more spendy, about $500, of which about $180 was their labor.
The w/w fluid and valve cost me $125 and about three hours of time. The methanol in the fluid is also toxic but as an earlier poster noted, animals aren't attracted to it like they are to antifreeze and it's not supposed to corrode the rims like CaCl2.
   / DIY tractor weights ideas #37
I've had dogs/cats living in my shop for 21 years. At the peak, 5 dogs and 2 cats. It's common for there to be antifreeze spills on the floor or open pans of it sitting around. Never had an incident. Guess it's lucky my pets aren't morons like me. :)
A dealer by me will put beet just/rim guard into the tires for a little more then 300.!
   / DIY tractor weights ideas #39
I got a quote for beet juice in my bobcat ct440 of just over $200 for the rear tires. That was me taking the tires to them. I believe they said it would increase the weight by about 385 bounds per tire?
   / DIY tractor weights ideas #40
That's very cheap if you mean $200 for the pair!!!! That's .26 cents per pound. Very cheap weight!!!!
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
large capacity skid steer bucket (A56857)
large capacity...
