Pouring Hydro oil from pail.
   / Pouring Hydro oil from pail. #1
eman5oh
Cortland NY
Kioti CK35HST
I am doing my 50 hour service and was wondering what other do to get the fluid out of the 5 gallon pail into the tractor without making a mess. I did see some pail pumps at TSC stagically placed near the 5 gallon pails of fluid. If i recall they were $25-$30. It got me wondoering how well they work or if there is a beter way to transfer the fluid. I have a funnel and hose, but htink it could get messy. What do you use or do?
   / Pouring Hydro oil from pail. #2
Get one of those...they're worth every penny!
I have one and it does a grfeat job
   / Pouring Hydro oil from pail. #3
I use a large flexible funnel and always have the spout at the top of the five gallon pail when pouring.
   / Pouring Hydro oil from pail. #4
Agree with getting one. I bought the TSC one many years ago. Still working fine.
HF also sells one for 1/2 price of TSC. Might be worth a try.
5 Gallon Oil Pump
   / Pouring Hydro oil from pail. #5
If you think you'll have regular use for it, I'd agree with the posters above. If long time between uses, it's a chore to clean the thing out, and you don't want it sitting with any fluid in it for the years before next use (getting gunky, sticky and dusty) - you'd want to clean it out very well.
Another option (the one I did when doing my 50 hour service) is to pour a gallon from your 5-gal container into a very CLEAN 2-gallon bucket (or other clean large container with open top and spout). Then pour from that into the funnel going into your hydro fill hole. Works like a charm, and allows you to measure the fluid as it goes in. Easy cleanup afterwards, and the bucket has 1001 other uses. :thumbsup:
   / Pouring Hydro oil from pail. #6
Ran into the same problem. I solved it by pouring into a gal jug (clean) I had. First couple of gallons works good, then the bucket is light enough to pour directly. A pump would probably work good too, but I'm cheap:cool:
   / Pouring Hydro oil from pail. #7
Same idea as TJ, I bought a bought two 2 1/2 gal containers and used one to pour from after refilling with the 5 gal bucket.
   / Pouring Hydro oil from pail. #8
I have the HF pail pump, cheap plastic but it works. I tried the long spout funnel but that was slow and messy the first time. I work my BX hard so change fluid and filter every 300 Hrs. Have 1200 Hrs in 4 years of working it. Also change hydraulic implements often so lose a little there and top up a quart here and there. I keep a plastic bag over the pail to keep it all clean.
Ron
   / Pouring Hydro oil from pail. #10
I've transferred from 5 gallon to smaller containers also, using a battery powered pump, then placed the smaller container next to my fill point, and used the pump again. I don't recall where I ended up buying mine, and there are many out there, but search for "Battery-Operated Liquid Transfer Pump" and you'll see a bunch.
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
(INOP) HUSTLER EXCEL TURF BATWING MOWER (A57192)
(INOP) HUSTLER...
Colombo Twin Master (A53317)
Colombo Twin...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
2021 Chevrolet Colorado Crew Cab 4WD Pickup Truck (A55852)
2021 Chevrolet...
2012 Volkswagen Tiguan AWD SUV (A55853)
2012 Volkswagen...
