Hydraulics quit
/ Hydraulics quit #1
nwentz
knox,in
john deere 300d
John deere 300 tlb diesel, noisy coming from the front , where my pump is for the power steering and loader, quit working.. Checked coupler seems ok, and removed the horizonal filter and checked, how to check the pump and oil level coming from the transmission, thanks, Norm
/ Hydraulics quit #2
:welcome: to TBN
Oil level check is dipstick in parts photo. Check oil with engine running. Install a 5000 psi gauge in tee in line on RH side of tractor that power steering supply line attaches to. Pressure should be around 2250. Are you positive that hyd pump shaft turns with engine crankshaft?????????????
/ Hydraulics quit
I think is my coupler now spline must be out, where is the transmission screen ive read about on this tractor, do u know, thanks, Norm
/ Hydraulics quit #4
Screen is parts key 15 hide behind a fitting with a hose attached on ind models.
/ Hydraulics quit
the screen on the left side of tractor buy the filters?
/ Hydraulics quit #6
Sorry nwentz but screen is accessed on right hand side of tractor while viewing tractor from behind it.
2020 Inifiniti Q 50 Sedan (A61574)
2020 Inifiniti Q...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
UNUSED WOLVERINE RPR-12-72W-72" RIPPER (A64281)
UNUSED WOLVERINE...
2 Wheel Homemade Trailer (A64119)
2 Wheel Homemade...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
