BX snowblower "oil level" question
/ BX snowblower "oil level" question #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
On the blower it says check the oil level before use, are they referring to the hydraulic oil in the tractor? Or is there a fill on the blower itself?
Thanks
/ BX snowblower "oil level" question #2
On mine that refers to the gearbox oil on blower. Checking each time is, IMHO, overkill. Long winters here and I check three times. Never had to any oil.
/ BX snowblower "oil level" question #3
There should be a check hole on the gearbox of the blower, about halfway up the box.
Thanks guys
/ BX snowblower "oil level" question #5
I check and top off mine once a season, unless I see evidence of oil leaking (so far none). I use big truck hub oil and it works good. The containers even have the little cone shaped nozzle for stuffing into the little hole and squeeze the liquid in until it runs out.
/ BX snowblower "oil level" question #7
Do not forget to oil the chain on the blower, I used to do it every other outing. China saw oil is recommended, also check the tension on the chain.
As to chain lube, motorcycle chain lube is probably the better route to go as it clings rather than flings, also designed for that sort of 'crappy' environment.
/ BX snowblower "oil level" question #8
Motorcycle chain lube and synthetic gear oil is what I use on mine. Surprisingly the chain don't collect much if any crud being behind the blower. Snow melt is probably the biggest concern.
/ BX snowblower "oil level" question #9
I think the manual for the blower calls for chainsaw lube. I do not have the blower or manual anymore since I sold my BX.
/ BX snowblower "oil level" question #10
I use tacky motorcycle chain lube on mine as well, just made good sense. Do not understand how chain saw lube could be better in this application. Also, running Mobil 1 80w-90 synthetic in gear box. Yesterday was my last mow of the season, snow blower is installed, waiting on the white stuff! Philip.
/ BX snowblower "oil level" question #11
Chain lube has same characteristics as motorcycle chain lube in that both have ingredients designed to prevent flinging.
Use ordinary oil in your chain saw and the results will be evident vert rapidly, especially if cutting over a snow base as you'll soon see an oily streak of slung oil. Your pants leg will also be oily.
/ BX snowblower "oil level" question #12
Motorcycle chain lube comes in a spray can with a nifty extension tube that makes it easy to spray in the cover to coat the chain ;) Easy Peasy. Philip.
HLA Attachments Loader Forks (A64119)
HLA Attachments...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
Claas Lexion 400 Series Combine Parts and Service Manuals (A63117)
Claas Lexion 400...
Caterpillar D8N Dozer Service and Parts Manuals (A63117)
Caterpillar D8N...
1991 25ft Wellcraft 250 Sportsman Boat and 2008 T/A Boat Trailer. (A61574)
1991 25ft...
2004 Ingersoll Rand SS-3 Portable Air Compressor (A61572)
2004 Ingersoll...
