OP
hillsandtrees
If no implement is on the rear that requires hydraulics, the two PB lines are "looped" or hooked together to keep the continuous flow (post #6 above). Please do some searching-there are hundreds of threads on this-not necessary pertaining to your 2370, but the theory is the same for every tractor. What your doing is no different than the many "adding a rear remote" threads, just your valve is mounted on the implement and not the tractor.
Here is the way JD does it:
Now it makes sense.
I didn't really understand the concept of open-center hydraulics.
Thanks for your time.
