OP - is this your project?
I am going to follow this one closely, as I have a similar project. There is a right of way running thru the middle of my hayfield and it seems the only time it is used is when the ground is soft. so the ruts are huge and the folks using it tend to run into the hayfield to avoid the ruts and they make new ruts. i am going to move the right of way in stages and am also looking for pointers on gravel road construction. I do have to remove some trees and the stumps to reroute the road. sorry if this seems like a hijack, it was not intended as such, just looking for some gravrel roadbuilding tips.
I have a Kubota MX5100 HST (4wd). I am looking to purchase a box blade and was looking for advice on size. would this tractor be able to pull a 6 ft box blade? the loader is 6 ft and I can dig some pretty good holes with it.
I am looking to prep a dirt path to be able to put down gravel and an looking to go about 4 inches deep and 10 ft wide.
any thoughts or advice would be appreciated.
Thanks,
Although a BB and FEL might be able to do it, that project is of ANY decent length cries out for rental of a bulldozer.
I have a similar sized Kubota(
L4240 HSTC) and a six ft. box blade.The only time my tractor has been in low range was pulling my BB;it handled it fine but it was a load for sure.You should be fine with a six ft.
Have you tried a 2 bottom plow in heavy clay?
IMO...Weight helps but is not really that big of a factor when it comes to box blades...however, for commercial work bigger/heavier is usually better...wider is better regardless...<snip>
Again, in my experience...weight is over-rated when it comes to grading etc. implements..<snip>
"Weight" comes in several forms - weight due to thickness of metal, weight due to the size (;ength) of the implement, weight due to piling "stuff" on are far different. In box blades the weight of different implements of the same size usually indicates the extra "beefiness" of the unit.
For example
Everything Attachments sells box blades.
Comparing two of their "house" brand and a King Cutter in the 72" size they have weights of:
500 lbs - King Kutter
515 lbs -
EA XTreme Duty Box Blade
635 lbs - Category I & II Severe XTreme Duty
I dare write that the Category I & II Severe XTreme Duty BB will put up with more beating than the other two. I'm willing to bet that if you put concrete blocks on top of the King Kutter it would stand less abuse than the "Category I & II Severe XTreme Duty".
And if you pile weight on top of a heavy duty BB it will definitely dig deeper in tough situations. I've a 5' KK that when I'm going into clay just about requires 200lb of weight on top, with either of my tractors.
I've an
M4700, the same size as yours. Based on my pulling of my 5' blade (bought for my 23hp
B7610) in heavy clay, you will probably be able to handle a 7' footer in decent soil. But you may need loaded rears.
I still think for a one time clearing of a 4" deep, or deeper, 10' wide path a weekend rental of a bulldozer or skidsteer would be a better approach.
