The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
Just wanted to thank everyone on TBN that contribute to these posts. After reading through hours of posts I just put the order in with Jeremy for a 54" Wicked Root Grapple for my L4740.
Great choice. :thumbsup: We look forward to seeing pics once it's installed!
Travis
Yaupon is taking over the country here in Deep East Texas. We have a new 5555 Mahindra. When I bought it, my dream was to be able to clear Yaupon and other undesirable brush. Currently we are experimenting with an inexpensive 72 inch tooth bar on our 78 inch bucket. Is it realistic to use a Wicked Grapple on Yaupon and what size would be appropriate? The Mahindra is 55 hp and weighs 6,000 pounds.
Your tractor has impressive weight and lift capacity, which can not be judged by th 55 HP rating.
Our Wicked Grapple for Compact Tractors is out there on similar tractors....no reported issues, but, ideally I recommend our new Wicked Grapple for Utility Tractors.
Concerning the yaupon, i'll direct you to rlgustafson....we do not have any such thing here in NC!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #793
Travis
Thanks, Travis. I'm leaning toward the 72 inch single lid root grapple for brush and "small roots". Consider yourselves lucky you do not have Yaupon. Evidently, I will need a backhoe to attack it. When will Everything Attachments begin making those?
That's a good choice. Some people choose smaller sizes for maneuverability and pushing power. Your tractor should be plenty capable in the pusing power department!
No plans for making backhoes.
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #795
Well after a slight delay it arrived in good condition. We had a beautiful week of weather and put it right to work. Thank you all again!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #797
Well after a slight delay it arrived in good condition. We had a beautiful week of weather and put it right to work. Thank you all again! <img src="http://www.tractorbynet.com/forums/files/attachments/446338-wicked-root-debris-grapple-151104kubotagrapple2-jpg"/><img src="http://www.tractorbynet.com/forums/files/attachments/446339-wicked-root-debris-grapple-151104kubotagrapple1-jpg"/>
Perfect match for your tractor.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #798
   / The WICKED Root & Debris GRAPPLE!!!!!!! #800
I could be wrong, I often am, but here is how I ran the hydraulic lines on my 5555 for my Wicked Grapple. First we used a retired team roping rope passing it through the tractor from the back to the front where we thought the hoses should go, marked a place on the rope about midway of the front cross brace on the FEL and pulled the rope out. Then stretched the rope straight and measured it. It was 21 feet and I added a foot just in case.
My local auto parts house makes hydraulic hoses. They get $.32 an inch for 1/4 inch ID, .34 for 3/8s and .39 for 1/2 inch. It was only $11 more to go with 3/8 and even though it is merely 50% larger in diameter it actually flows 2.25 times as much fluid which would make the lid a little snappier.
The Wicked Grapple comes with Pioneer style quick disconnects, one male and one female. This is pure genius. Every manufacturer of tractors and attachments should have one male and one female. The reason becomes obvious in the picture below. It allows the hose ends to be connected together when not attached to an implement, keeping them clean and avoiding problems if the operator grabs the wrong handle.
My auto parts man asked me if I wanted straight or 90 degree or some other angle fittings. To keep things neat and tidy out back, I went with 90s so that there would not be big honking 180 degree bends flopping around. The 90s also made it easier to take advantage of the male/female connectors up front.
For the time being, zip cords hold the hoses. After we get the grapple and settle on the final configuration, we will use screwed on clamps to secure the lines. It looks like 22 feet is going to be too long, but that's better than too short.
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
Caterpillar 906M (A53317)
Caterpillar 906M...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
