Hay Stacking block/tackle grappel hook set up.
/ Hay Stacking block/tackle grappel hook set up. #1
powerscol
SW Colorado
CT 235
Was out trying to stack hay last night and there has got to be a way to do it easier. I need to lift bales 8' to get to the top of my stack. I was lifting stair steps up each row of bales, and it got old quick. Its just me doing this. I have a metal building with good c-channels holding up the roof. My idea was to use a clamp on the c-channel and hang a simple block and tackle with a hinged hook (like the old ice block hook) to lift a single bale so I can stack.
I can find the clamp and a simple double block, but I cannot find a simple hinged grapple hook that will work on a hay bale (open at least 18" and sit down the side of the bale, or possibly something to lift by both strings. I guess I could use two hand hooks and some sort of 3 ring set up under the block.
I do not have the skils or equipment to fabricate this, so if you know of any sources for what I need, please speak up. Harbor freight and Granger have the block/tackle, ring set up I can use, but I have found no hook source yet that will work. I have also looked locally into the antique hay hooks, with no luck.
Thoughts?
/ Hay Stacking block/tackle grappel hook set up. #2
I usually make a plateau at 3-4 bales up and toss the a half dozen bales up to there. Then I go and up and stack from there.
Less climbing stairs that way and much faster than a pulley and hook would be.
If you have the space, a hay elevator also works well.
Aaron Z
/ Hay Stacking block/tackle grappel hook set up. #3
A short tube steel / chain hay elevator?
Would ice (block) tongs or log tongs work? The chain type log tongs? 55 gallon barrel lift hoists?
/ Hay Stacking block/tackle grappel hook set up. #4
Thoughts?
There's no way I can tell from here whether your roof would support what you are attempting to do.
My advice is to get a hay elevator. I 've used the "stair step method" for 80-90 pound bales and it works well. But I'm a little long in the tooth to do that now.
Another alternative is to get a few friends (the ones that wear a number 46 jacket and a #2 cap) , ply them with an adequate amount of beer, and then let them hand you the bales. Or better yet, you supervise them as they pass the bales one at a time to the top of the stack (grin).
/ Hay Stacking block/tackle grappel hook set up. #5
Is the top of the stacked hay 8 foot high? If it is and your in good shape, it's easier to throw hay up than carry it up a stair step of hay bails. You have to use good ergonomics. Grab 2 strings, swing back and then swing them up at speed and let loose as you bring it up. With practice, it's actually easy compared to other ways.
You may not be able to get to the top row when standing on the barn floor but if you are unloading it from a trailer, farm wagon or truck, you're already standing about 2 feet up so you only have to get the bail up to about head level.
/ Hay Stacking block/tackle grappel hook set up. #6
What about using an old hay ejector or kicker pan from a NH or JD baler ? Not sure what your hay storage arrangements are, but if they have to go up, an elevator either chain or belt type is traditionally used. But, having a kicker pan sending them flying would earn you extra points.
If I was to use a simple block and tackle system. I would opt for a frame to lift 8 or 10 at a time in a layer and then drop the layer on the previous one. There are some grapple frame systems that do this in the field. Then they use a front loader frame which clamps on the layer to load it onto a stack or a trailer/truck.
/ Hay Stacking block/tackle grappel hook set up. #7
This^^ I'm 5'9" and have stacked 6 high using this method with CA red oat (100lb bales) back when I worked at the feed store. Hay hooks can be a good help too. If you leverage them properly, you can fling those babys up pretty high.
Or you could use the FEL on your CT. Curl the bucket forward, and stack three or four bales on it, lift and presto! Much faster than lifting individual bales with ropes and hooks.
Chris
/ Hay Stacking block/tackle grappel hook set up. #8
I rigged a carry all with a deck to replace the bucket on my fell. Loading 12 bales at a time eliminates a lot of climbing.
/ Hay Stacking block/tackle grappel hook set up. #9
I would do this long before I tried block and tackle for a mere 8 ' lift.
/ Hay Stacking block/tackle grappel hook set up. #10
I have to agree with others, seems like way overthinking it for a small stack of bales. Worst case, hire a couple of 15 year olds.
First my tractor and grapple wont fit in this small bay. Works great in the extension. I have tried the 15 year old kids and I can still out move them. They don understand hard work. My back will not allow much throwing, but I have done that, pitching up 2 rows at a time. That's what killed me this time
The small hay elevator has me curious, but what brand are good ones and what do I look for when shopping. Never seen one around here, just pictures.
/ Hay Stacking block/tackle grappel hook set up. #12
I don't know anything about brands, I'd just check Auctionzip for local auctions that have one, and go bid.
/ Hay Stacking block/tackle grappel hook set up. #14
I have two hay elevators. One big 20-foot one (Snowco Brand) and another one that is probably 50 years old that i have no idea what brand, I cut it down to 9 feet. They both have an electric motor and work pretty well.
/ Hay Stacking block/tackle grappel hook set up. #15
An electric hay elevator would be great. Even if you found a pto powered you could eventually convert to electric motor for more convenience and be safer. Of course you would want someone to load it and someone to unload it.
Keep an eye out for a used on on craigslist or the like.
/ Hay Stacking block/tackle grappel hook set up. #16
There is about six hay elevators in my area for sale, for about $300-500 on god ol' craigslist. I'm sure you won't have a hard time finding one.
/ Hay Stacking block/tackle grappel hook set up. #17
A trebuchet, there's so much you can accomplish with one! Great for stacking pumpkins too, sort of.
Seriously, a B&T is probably too much trouble for an 8' lift. a double purchase would be a lot of rope hauling. Maybe a home made counterweighted pole boom would work, but I favor helping out the unemployed 15-16 yr olds.
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
