Any advice for chains/straps without hacking up my tractor or trailer?
   / Any advice for chains/straps without hacking up my tractor or trailer? #11
These are what I use on my BX25 (not my tractor/trailer pictured). They work perfectly and probably took all of 5 minutes to install. They offer the perfect attachment points for a BX25D IMHO. I ordered a set of custom length straps and marked each one's position and have any excess strap permanently secured. Instant on and off with no untidy loose ends.
Your allowed to use rachet straps in you're state? ? I think in Michigan its chains, maybe result heavy straps. Only have ever used chains. Don't need to risk a ticket
   / Any advice for chains/straps without hacking up my tractor or trailer? #12
Straps are legal for wheeled vehicles under 10,000#
With that said he needs to lower the BH and Bucket to the deck and put a strap over each. It's the law. The only exception is if they are pinned.
Chris
   / Any advice for chains/straps without hacking up my tractor or trailer? #13
Chris
Again not my BX or trailer, but why would he need a strap on the BH? The BH is what is actually strapped down in the rear..
   / Any advice for chains/straps without hacking up my tractor or trailer? #14
Each implement has to be secured.
The front end loader has to be secured. Strap or chain the fel bucket to the trailer.
The back hoe has to be secured. Lower the bucket to the deck and strap the bucket to the trailer.
Those 4 little straps are not going to hold that 2500lb BX25 on that trailer in an accident.
IF that vehicle hits something and stops violently, the backhoe most likely will swing one way or the other.
You want that BX25 to stay on the trailer and not become a 2500lb object flying off the trailer.
:2cents:
   / Any advice for chains/straps without hacking up my tractor or trailer? #15
Not arguing at all, but in the picture the BH (assembly) is secured. What if the straps are rated at 10k lbs breaking strength and 3333 lbs working load. The working load is 2.5X the load weight in any direction, breaking strength is 8x load weight in any direction.
   / Any advice for chains/straps without hacking up my tractor or trailer? #16
Argue, disagree, whatever you want to call it. Both backhoe and FEL buckets need dedicated securement. Period.
Anyone in D.O.T enforcement at any level could write this BX for a minimum of two securement violations.
   / Any advice for chains/straps without hacking up my tractor or trailer? #18
It's the law. All implements must be strapped separate. A BH or FEL must be strapped down or pinned.
Chris
   / Any advice for chains/straps without hacking up my tractor or trailer? #19
The BH is strapped down, the strap attachment points are on the BH.
   / Any advice for chains/straps without hacking up my tractor or trailer? #20
I believe what they are saying is that the backhoe bucket itself must be strapped, to keep it from articulating or swinging out of position...
DEWALT ROTARY HAMMER (A50854)
DEWALT ROTARY...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
