Compressor piping or hose Question
/ Compressor piping or hose Question
Thanks George 2615...........the Canadian version of TSC store in Sault Ste Marie Canada , doesn't carry but your link shows the American TSC in Sault Michigan does so next time I am across the river (maybe getting 20 gallons of gas for truck ) I will check out their store ...thanks everyone.
/ Compressor piping or hose Question #22
Don't know how your setup will be configured, but you may need a hose with swivel on one end.
Terry
/ Compressor piping or hose Question #24
Dave, I don't know the name of the clamps, but I get them in bulk from my local industrial hydraulic supply. I think they're quite common. For your clear braided hose you need #13 for 1/4ID , #14 for 5/16ID and #15 for 3/8ID.
I'll look in my Acklands Grainger catalog tomorrow unless someone else knows what they're called.
Terry
Ok thanks :)
Couple of good hydraulic guys local who will probably have them then.
/ Compressor piping or hose Question #25
Here you go Dave.
image-1943648755.jpg Terry
Ignore the typical Acklands Grainger retail plus 200% pricing.
/ Compressor piping or hose Question #26
Terry, I have that pliers for automotive cv boot clamps, where did you get your small clamps?
Standard at parts stores?
Those are called oetiker clamps, and you can buy them on Amazon, ebay, etc. Google oetiker clamps and you will see lots of suppliers.
/ Compressor piping or hose Question #28
Why not buy a 25' premade hose from TSC and cut 2-3' off one end. Then get a hose barb to connect one end of the 2' hose to the compressor and the other end or female end of 2 foot hose get a quick disconnect adapter to hook to the reel input. The get another end for the 23' hose and you have a spare hose.
I wouldn't waste my money on a high pressure hydraulic hose for a 100# air compressor.
/ Compressor piping or hose Question #29
You can get 3' hoses from Northern Tool. I just picked up 2 today for a very similar reason. 3/8" rubber hose with 1/4" MPT fittings on each end $12/ea Add a union or standard pneumatic hose connectors to make it work. If you don't have one locally, you can buy online. Shouldn't be that hard to find...
/ Compressor piping or hose Question #30
Harbor Freight has short hoses too.
/ Compressor piping or hose Question #32
I ran a millwork shop that used copper tubing with soldered fittings throughout. No rust. No leaks. Worked great. Pricey.
I buy long pre-made hoses and cut them to the length needed - often cheaper that buying plain air hose by the foot. Use barbed fittings with SS hose clamps - never had an issue in 35 years.
/ Compressor piping or hose Question #33
Wawajake,
What did you use for your connecting piece ?
/ Compressor piping or hose Question #34
...........The barbed fitting should hold the connection by itself, the clamps are just a safety added thing.........
Years ago i had a bit of welding slag put a pin hole in my air hose with the resultant leak. I cut the line and just used a brass barbed hose connector like this one and I didn't use any clamps. It's held leak free for years now without any problems. The reason I decided to go the no clamp route is because the clamps would have been always hooking on stuff including my hands as I rolled it up and I had some 300 psi working pressure line that I used on a Stock Car that was made to be installed on a barb without any need for a clamps. I decided if that line can hold without clamps, I'd see if an air hose line would too...and it did.
/ Compressor piping or hose Question #35
True, no clamps are needed if the barbed fitting is sized properly.
My hose/barbed fitting/clamp setup was used for a shop setup.
If I go for longer hoses on a mobile setup there would be automotive type air fitting.
I am in the building process for my new shop and I will use the pressure hose for this shop also. Metal pipe can add water in the system if used in cold climates and copper tubing, if not drained can corrode leaving debre in the lines.
The rubber hose installs easy, no special tools and one person can put it up.
Ltr
/ Compressor piping or hose Question #37
Sorry, but that is completely unnecessary. You can do it if you want, but simple soldering/sweating is fine. I work in a fortune 500 industrial complex, and all air lines are Copper that are just normally soldered. They do use the blue (type L) copper, so it is thicker than the ultra thin M (red) but other than that, it is just like any plumbing. If it is good enough for this incredibly liability averse company, then it works for me.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
