L3400 sight glass
/ L3400 sight glass #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
My sight glass finally bit the dust and cracked.
Noticed a wet spot on the concrete about 4" diameter and it was pretty wet around the glass. Sure enough it was cracked.
So I guess time to order one. I was hoping I dodged the bullet on this common issue since the tractor is 9 years and 900hrs old.
Got a 3/4" pipe plug in there now til I can get one ordered.
Keep an eye on that area fellow owners.:thumbsup:
/ L3400 sight glass
Funny you posted that, cause I was thinking the same exact thing. Looking at this one Sight Glasses & Flow Sights | MSCDirect.com
Wondering if any others have done this? All the threads I was reading from 5-6 years ago indicated ~$10 for kubota plastic.
Seems they are up to $25 now so thats why I started looking. Heck, I can get a non-kubota plastic one for $5. So I really dont wat to pay $20 extra for the kubota wrapper that I am just going to toss.
Those that have bought the kubota replacement, an issues out of the grey plastic ones?
/ L3400 sight glass #5
Mine gave out at around 350 hours a few years ago. The new one is gray and the dealer said it is the improved one. So far OK, We'll see.
/ L3400 sight glass #9
I had the same issue with mine at about 350hrs. Got the Kubota gray plastic replacement and it is cheaply made. Don't over tighten it, you will strip it instantly.
I like the metal ones that the other members posted. When I change out the transmission fluid in another 50 hours, I'll change to that one.
/ L3400 sight glass #10
Are you talking about this sight glass?
How in the world did you break it?
/ L3400 sight glass
Yep, broke all on its own.
My guess is the cheap plastic + range of hot cold and the plastic and casting expanding at different rates.
Separated right where the threads meets the head
/ L3400 sight glass #13
My original sight glass (AKA cheap plastic crap) broke. When I tried to screw in the new improved replacement, it just wouldn't go no matter what I did. It took me a while to realize that the threaded part of the old one was still screwed in, with the top of it recessed about 3/8" down in the threads. Once I was able to turn it out, everything went smoothly. My question is, does anyone have a trick for seeing the fluid level in the glass? I never feel confident that I've really seen the level.
/ L3400 sight glass #14
When I had my L2800HST had same setup sight glass as your L3400 …" My question is, does anyone have a trick for seeing the fluid level in the glass?"... I made sure to check fluid was half full each new day of use. :confused3:
/ L3400 sight glass #15
Believe the green folks sell a dye that helps to increase the visibility in both the sight glass and the dip stick
/ L3400 sight glass #17
I've never touched mine & saw it was leaking. The threads had separated from the body. These are just bad news.
/ L3400 sight glass #18
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
Briggs and Stratton Generator (A65579)
Briggs and...
Landhero Rigging / Binding Chain / Suspension Equipment (A66408)
Landhero Rigging /...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
Panorama Hay Rake (A66408)
Panorama Hay Rake...
2013 MACK PINNACLE (A65643)
2013 MACK PINNACLE...
