Bx5450 new install any tips tricks?
   / Bx5450 new install any tips tricks? #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Have to put together everything including mid mount, how hard is it and any tips or tricks? Everything new in box
   / Bx5450 new install any tips tricks? #2
I bought the older blower last fall but put together in 1 evening, pretty straight forward. A wood dollie for the blower helped to install/unistall easier, the ones-lowes,menards or harbor freight sells.
   / Bx5450 new install any tips tricks? #3
Check the auger gearbox for lube.
   / Bx5450 new install any tips tricks? #4
I agree that the furniture moving dollies are a great thing to use. I keep my Ratchet rake, snow plow, mid-mount, and blower on them. Makes it a lot easier to install as I cannot get my tractor into my garage but with the dollies I can roll the equipment to tractor and install. I also can move the blower into my shop to melt the ice after using it. Remember to get extra shear bolts for both the auger and the impeller as well as a small drift pin for driving the broken pieces from the shaft. If your blower has a chain drive get bar oil or other chain lube for lubing every 10 hours or so.
Thanks for for replies, so far I got the mount put together and will be cracking open the blower which is still in crate hopefully sat am, I'm assuming there is no chain but have not looked yet.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
John Deere 4520 (A60462)
John Deere 4520...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
