Mac's 8N
   / Mac's 8N
Ah yea thanks. That probably would have been a better spot for this thread. Maybe I should move it there. Assuming I can figure out how!
   / Mac's 8N #23
Ask the TBN Admins to move the thread... Catherine is the 'go to' girl, you see her mainly welcoming newbies and occasionally shifting their 'introductions' over to a more relevant Forum.
   / Mac's 8N
Cool. Sent her a message, hopefully this string can be moved to a more appropriate home.
   / Mac's 8N
Ok guys, can't for the life of me figure out how this thermostat is supposed to fit in the rad hose. It seems way too big. I can get the one end in, but I can't get the lip in to get it into the actual hose. Anyone tried this type of thermostat before? Is it just a matter of oiling it up and continuing to work it in or is there some other trick?
   / Mac's 8N #26
It goes in the hose?? I never knew that. Thought it went under a flange that the hose hooks to. Kind of like a car. I'll have to look at my 801 tomorrow
   / Mac's 8N
I will have to check and see if there is anything in any of the manuals, all references I have seen online seem to refer to inserting it into the hose about 1/3 the way towards the block.
   / Mac's 8N #28
It may very well go in hose. I've never had to replace one.im sure someone on here will be able to help you.
   / Mac's 8N
Alright, seems it goes in the hose, according to the manuals anyhow. Now I just need to figure out how to get it in there.
   / Mac's 8N #30
Hmmm... Maybe heat the hose up some, then put a little Vaseline inside. Then wiggle or tap in in with a 11/2" pvc pipe or something?
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
