John Deere 2010 Diesel trouble
   / John Deere 2010 Diesel trouble #21
As you stated glow plugs are activated by ing switch. IIRC regulator only controls charging voltage but has nothing to do with GP operation. GP's heat up so that fuel/air mixture in cylinders is easier to ignite.
For starting the fuel spraying on red hot injectors lights the air fuel mixture . As there is not high enough combustion chamber temperatures. With a cold engine and slow cranking rpms .
   / John Deere 2010 Diesel trouble #22
My John Deere 5205 does not have glow plugs or red hot injectors. It has just a heater for the air intake and it starts with no problem.
   / John Deere 2010 Diesel trouble #23
Quebecguy
Ok thanks for your reply. JD 2010 was built from 1960-1965 while JD 5205 was built from 2000-2007. Would you care to guess the number of diesel technology advancements that's been made in those 40 yrs??? I'll guarantee you that your 5205 engine doesn't have pre-combustion chambers similar to a 2010 diesel
   / John Deere 2010 Diesel trouble #24
Darn it all. I meant red hot glow plugs , not red hot injectors . It's the difference between the precombustion chamber design with glow plugs. And the open combustion chamber that can not use glow plugs. Thus the intake manifold heater that uses electricity or burning fuel.
   / John Deere 2010 Diesel trouble #25
Sorry , a grammar error there . Cold weather starts are via the injectors spraying fuel on the red hot glow plugs .
   / John Deere 2010 Diesel trouble #26
Following this thread.
DANPAUL1, brother, I am a slow reader to begin with, but could you PLEASE add a PERIOD to separate your sentences! (or at least a few spaces)
Please keep this thread updated as I am helping a neighbor with his 1963 2010 and I am learning from your questions and...well, from TX Jim.
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
