Makes perfect sense!
/ Makes perfect sense! #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Makes perfect sense that a foreign welder will work better with foreign welding rod. :laughing:
This Everlast PowerArc ST is just like my PowerArc 200. It really likes ESAB's Sureweld 10P Plus 6010.
SUREWELD 10P PLUS | Welding Consumables | Products & Solutions
Don't know why the pipe pictures posts out of the correct rotation!:confused:
/ Makes perfect sense! #2
I take it you prefer the standard + and - ports over using the dedicated 6010 port on the welder when using 6010? (FWIW: I rarely use the dedicated 6010 port on my Everlast PA-300 but all I burn in the fast freeze rod class is 6011. I never run 6010 at home. The regular +/- ports are simply more like what I am used to with 6011 compared to my older transformer welders with 6011. I simply am not good enough to relearn I guess ).
No when running 6010, I use the 6010 port. That was the first picture I came across of the welder, so I used it. :D
/ Makes perfect sense! #5
But does it take a foreigner to do the welding?
Upon close inspection of MY 6010 beads one might conclude that I'm 'foreign to welding'. :)
Terry
/ Makes perfect sense! #7
/ Makes perfect sense! #8
Does the 6010 port just offer higher OCV for the cellulose rods or what's the deal with it ???
That is my understanding.
The automatic arc force works really well on this machine. When doing open root pipe welding, I can jam the rod right through the gap, to date I haven't lost the arc yet!:cool:
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2012 Ford F-750...
2021 Deere 550K LGP (A60462)
2021 Deere 550K...
2019 JCB 457 (A60462)
KALMAR 4X2 YARD MULE (INOPERABLE) (A60736)
KALMAR 4X2 YARD...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
