No seat on bh 77
/ No seat on bh 77
My BH77 on my B3300 doesn't have it's own seat and I don't want one either. It's an option to have the second seat, not just that the dealer 'forgot to put it on'. I'm 6'2" and have the seat set about mid-way on the slide tracks and happy with it in both forward and swiveled backward. I do a lot of quick stuff (like picking up a single rock) from the forward seated position with just reaching around behind me to run the controls. The flipped up second seat would all but eliminate this possibility.
I'm about 7 inches shorter and with the seat all the way to the back I cannot sit back and reach the controls.if I have to I'll do my own seat
/ No seat on bh 77
I have a 3rd party hoe on my B2650 but.....is it possible that the mounting hardware for a BH77 is different depending on whether the tractor is equipped with a factory cab or is open station. The factory cab (which I have) necessitates that the hoe be equipped with its own seat and it would seem to me that the hoe on a cab model needs to extend further back to accommodate the seat and allow clearance to the back of the enclosed cab. Just a guess on my part but if the mounts are different then you (escavader) may have the cab mount hardware..Again just a guess.
there looks like enough room for a seat at least for me I'm not that tall .i want to get out of one side step on the tire and sit in the other.constantly flipping the seat is a pain I hated it on the bx and I hate it now
/ No seat on bh 77 #13
What are you constantly flipping the seat for, re-positioning hoe for trenching or picking up of single rocks/limbs?
/ No seat on bh 77
I do a lot of trail maintenance for my atv club turning around in my forward facing seat will kill my back in a few hours
/ No seat on bh 77 #15
While it's worth chasing them up, (because you have the skills to make your own) doing it yourself and getting it exactly where you want it may be a bonus, as the position of the OEM may not be ideal. Good luck with either outcome!
/ No seat on bh 77 #16
Looking at the hoe picture in your "Super B" post and comparing it to my BH75...it appears that the control levers for the 77 hoe are longer and angled back for the "swivel seat". On my 75 the control levers are straight up for use with the separate hoe seat. I don't think those angled one would work even if you fabricated your own seat assembly. You'd probably have to swap out the levers.
/ No seat on bh 77
Looking at the hoe picture in your "Super B" post and comparing it to my BH75...it appears that the control levers for the 77 hoe are longer and angled back for the "swivel seat". On my 75 the control levers are straight up for use with the separate hoe seat. I don't think those angled one would work even if you fabricated your own seat assembly. You'd probably have to swap out the levers. <img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/444480-no-seat-bh-77-a-b3030-1-jpg"/>
so can someone with the bh 77 with a seat tell me if you have straight or curved levers please
/ No seat on bh 77 #18
I haven't seen a new 77 with a separate seat. I'd call your dealer and ask him if the 77 is available with a separate seat. If it is, the levers might be swapped out as part of the "hoe seat" option.
/ No seat on bh 77 #20
Straight here. Separate seat. 6'4" & no way I could operate controls from the seat. Couldn't get my knees far enough apart to clear sticks. Had to fab up new brackets to move seat back about 8". Much better now. It is pretty much impossible to reach hoe controls over flipped seat.
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
26120 (A56859)
26120 (A56859)
2015 Caterpillar CB24B (A60462)
2015 Caterpillar...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
