Quick Hitches john deere quick attach to skid steer attach
/ john deere quick attach to skid steer attach #1
jnewhard
Slatington, PA
John Deere 2032R
hey guys i have a John deere 2032r with a H130 Loader with the john deere quick attach. I been looking at getting the Skid steer adaptor for my loader but was wondering if it was worth it? is it gonna lower my lifting capacity? Just wondering what you guys think?
/ john deere quick attach to skid steer attach #2
I asked my dealer about the same thing for my tractor and he said it will lower the lifting capacity quite a bit cause the parts needed to make it a skid steer quick attack is quite heavy with all the plate.
/ john deere quick attach to skid steer attach #3
I just cant figure out why JD wont go with the flow and use the normal quick attach like everyone else. What is even worse is that the JD customers should DEMAND IT and do so at no additional cost!
That aside what is the weight difference for the Quick attach and do you really get anyplace near the max lift of your tractor during your regular usage? For my uses and the versatility of being able to use so many different attachments that are not specific for the JD quick attach and the cost of having aftermarket attachments built for the JD only hook up compared to everything else along with being able to use friends and families attachments or lend mine, would make the loss of a few pound of lift insufficient.
/ john deere quick attach to skid steer attach #4
SSQA is an option in the 3-series and larger tractors, so they have indeed "gone with the flow". SSQA does not make sense for the 2-series and smaller machines due to the extra weight and inability to really use any SSQA attachments.
/ john deere quick attach to skid steer attach #5
I disagree with the "quite a bit" part unless you where to use one of the available adapters on the market as they move the attachment forwards several inches. If converting your H165 to SSQA with the JD "holders" you should see virtually no difference in lift capacity.
/ john deere quick attach to skid steer attach #6
Yes, this is an old unanswered post-sorry we missed it!
It is NOT worth it for your machine-especially the "adapter" part as you loose to much lift. Everything your loader can make good use of is readily available in the JDQA setup like forks and grapples.
/ john deere quick attach to skid steer attach #7
Re-read corey9212's post. I have no problem getting FEL attachments for my 300CX... I just let them (the manufacturer) know that that is what I have.
There's really not a lot of attachments for a FEL when you consider it. Heaps of implements for the back end, which is why there are Categories. :2cents:
/ john deere quick attach to skid steer attach #8
Argue all you want but I even have a standard SSQA on my little JD 755 and would never waste my money on an attachment for a loader that only fits one brand. I have several buckets alone that are used between 4 different machines along with many other variable size and use specific attachments for my loaders including custom made one off stuff.
/ john deere quick attach to skid steer attach #9
I'm not arguing, Mate, just discussing. I also only have the one rig with a FEL.
As a discussion, a Skid Steer is designed to operate a very robust set of arms along with quite a number of equally robust attachments. Hence the (standardised?) Skid Steer Quick Attach [SSQA] is designed to to be equally robust & heavier.
A FEL is designed, as an optional attachment to a tractor (and each brand has there own design), to lift. Yes, we tend to abuse them by doing all sorts of things (like digging) but they're just for up/down/carry purposes.
I guess what I'm saying is that the 'front end' of a Skid Steer comes in industry standard sizes = an industry standard SSQA. The 3 point hitch of a Tractor comes in industry standard Categories = an industry standard 3PHQA (such as my Cat1 iMatch).
Are you suggesting that the tractor industry needs to standardise/categorise all FELs to accomodate all Skid Steer attachments? 'Cause a Tractor FEL isn't designed to work as a Skid Steer.
/ john deere quick attach to skid steer attach #10
Many tractor brands already do have the Skid Steer style QA. And I think that is the point he is trying to make.
I can bring forks or buckets from our skid steers at work home with me and they will fit right on my tractors QA.
/ john deere quick attach to skid steer attach #11
That's good and perhaps it will become the standard in the future if all of the FEL manufacturers can get together (or whatever the process is) to decide the best configuration... just as different manufacturers now offer their own versions of 3PHQAs. Having a 3PHQA is a blessing as far as I'm concerned.
As kennyd stated, An "SSQA is an option in the 3-series and larger tractors, so they [JD] have indeed 'gone with the flow'. SSQA does not make sense for the 2-series and smaller machines due to the extra weight and inability to really use any SSQA attachments."
/ john deere quick attach to skid steer attach #12
According to my dealer, to convert to the SSQA would be a special order and require fabricating so I wonder if that's where I would lose my lift capacity cause there would be a lot more metal and plate.
/ john deere quick attach to skid steer attach #13
With all do respect, your dealer is dead wrong.
From the sales manual: Skid steer attachment carrier
You need bundle # BW15244, here it is at GFP: Green Farm Parts: John Deere Parts Online at Discount Prices
Here is a picture from JDParts:
If you go to the online JD online build your own configurator, you can even option the H165 with the SSQA carrier when the machine is ordered.
Believe me yet? :)
/ john deere quick attach to skid steer attach #15
Hey guys...thought you might be interested in this. JD Hook and Pin Quick Attach on one side, Skid Steer style Quick Attach on the other. Priced at $385 with FREE shipping! Weighs 137 lbs. John Deere to Skid Steer Quick Attach Adapter 200 300 400 500 tractor loader
View attachment 444585 View attachment 444588
handy little adapter, i have sold similar on occasion,
but, as others have mentioned, when you put that on a tractor that only has 800 lbs
lift capacity at it's pivot pin, then increase the distance to the load the 4 or 5 inches further froward with the adapter,
then add the additional 135 lbs of the plate.. and oh yea, any bucket or forks are going to weigh more if built for
SSA, so you really can decrease performance in a large percentage on such a setup. on a 400 loader on a 4066R
or even a 3046r loader this isn't as much a reduction in capacity.
they have their place, but at a price, much lower lift performance.
/ john deere quick attach to skid steer attach #16
I've got the JD hook and pins on my 4300. got the original bucket plus another three units that replace it, plus a snow plow with power angle. Always thought that it was very easy to whip up another bucket, platform or whatever with the hook and pins,,,,
I often have my wife or some other assistant install or remove the lock pins but I know they would have problems swinging those spring loaded levers...
/ john deere quick attach to skid steer attach #17
I definitely understand. The levers surprisingly engage without much trouble.
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
2015 Ford Mustang Convertible Coupe (A61574)
2015 Ford Mustang...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A61574)
2007 30ft. Regal...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
