Box blade will not completely lower
/ Box blade will not completely lower #1
Skidrowe18
Member
Zebulon, NC
Kioti CK 3510
Hi all,
I have not used my box blade but was getting everything ready to start today. After getting everything connected I noticed that the blade would not lower completely. I turned the hydrolic speed control to various settings but does not seem to make a difference. The height at full lowered is 21 inches.
Here are some other shots...
This is a new tractor ck3510 and I m new this as well so hopefully it's just me doing something wrong;)
/ Box blade will not completely lower #2
It looks like your 3pt lift arms are not all the way down.They could be bound up with the box blade. If you disconnect the box blade will they go lower?
/ Box blade will not completely lower #3
Speed control is not the problem, lowering your 3PH is. I'm not familiar with your model Kioti, but you should able to lower the entire 3PH with the draft control and/or another lever, (can't recall the name) probably located next to each other. I suggest you read your owner's manual to get the idea on what to do. It's also possible your top-link is too short to allow the back of the box blade to touch the ground; hard to tell from your pics.....
/ Box blade will not completely lower #4
Hi all,
I have not used my box blade but was getting everything ready to start today. After getting everything connected I noticed that the board would not lower completely. I turned the hydrolic speed control to various settings but does not seem to make a difference. The night at full lowered is shot 21 inches.
View attachment 444239. View attachment 444242. View attachment 444245
It looks like your top is too long (the part that connects in the middle with the threads)...To check, either remove it or shorten it.
/ Box blade will not completely lower #6
Also make sure you don't have an adjustable stop on the 3pt raise/lowering lever.
/ Box blade will not completely lower #7
Based on your middle pic it looks like your lift arms are almost horizontal and have bottomed out and are binding preventing the arms from lowering any more. also the turn buckles look very loose. The lift arms should be more vertical to allow the arms to drop lower. Swap the positions of the lift arms and turn buckles.
I've attached the OP's pic and another CK3510 pic showing the proper position of the lift arms and sway link hook up.
/ Box blade will not completely lower #8
Turn your digging teeth over or remove them entirely unless you want to do some ripping, and shorten the top link about 4 inches. It is a jackscrew... just start cranking. you have the entire boxed pushed up at the front by the extremely long adjustment of the top link. Also looks like the side sway turnbuckles need to be shortened. looks like they are in a bind.
Thanks for the suggestions. I'll take look in the morning at these. I have some big pot holes that's I wanted to use the teeth so I lowered them and angled to try to take advantage if them.
/ Box blade will not completely lower #10
Well shorten that top link and shorten those sidesway turnbuckles that are now in compression and you should be good to go.
/ Box blade will not completely lower #11
I'd have to look at mine on a CK30hst but it almost looks like the lift arms for implements are on backwards. The hydraulic arms off the tractor case are angled down all the way as they should be for full travel but the vertical connecting links are angled way to much to the rear and should be more vertical.
/ Box blade will not completely lower #12
you have 4 connections backwards (2 on each side)
just swap your connection points and all should be good.
the bars / turnbuckles are all good. just you have them connected in the wrong holes in the lower lift arms.
swaping them around should also tighen up the "sway bar/chain" on each side as well.
Tractor Attachments And Skid Steer Attachments For Any Tractor Or Skid Steer = good amount of videos / detailed description of stuff. suggest taking a watch / read over a few of the videos on various box blades and like. that should cover the basics of a box blade setup.
/ Box blade will not completely lower #13
I'll 2nd this. The draft links are on the machine backwards by the looks of things. The turn buckles should be nearly vertical through the entire range of motion and they look severely kicked out to the rear. Alsl, I'll second or third the comments about the top link being way to long. Crank it in a bit. The box should be just out of level front to back depending on what you are doing with the blade.
/ Box blade will not completely lower #14
I see what you mean. The turnbuckles should be in the holes the lift links are in and the lift links should be in the holes the turnbuckles are in... Yeah that should solve both problems. Good catch.
/ Box blade will not completely lower #15
That's what I said in post #7.
/ Box blade will not completely lower #16
Hi all,
I would be very concerned about the dealer if this is how the 3 point was set up when you purchased it? Set it up as pictured in post 7 and then adjust top link and you should be good to go.
/ Box blade will not completely lower #17
Sounds like this may solve your problem. If not, review Coyote Machine's post about draft control. If your model has it, this could be the problem. I have an NX, and one day could not lower my implement. Turns out I had inadvertently pulled up on the draft control lever, which sits alongside the lift-position control lever. :eek:
Well that is exactly how it came from the dealer. I have been curious if this was correct for a while but assumed that it came that way from the dealer... I have also had a few other "issues" since I took delivery in the last month...
I'll switch them around and try that. Just curious if anyone else has picturs s of their rear ends (tractor only please).
/ Box blade will not completely lower #19
This is what yours should look like. Also shorten the top link so that the front cutting edge is just about 1/2" lower than the rear cutting edge for your work tomorrow.;)
Thanks for all the help. I'll switch things around and give it another go.
LG SENSOR DRY DRYER W/WHIRLPOOL DUET STEAM WASHER (A64281)
LG SENSOR DRY...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
20ft 2-Door Shipping Container (A61572)
20ft 2-Door...
2017 KUBOTA SVL75-2 SKID STEER (A64279)
2017 KUBOTA...
