Bush Hog for YM2000
/ Bush Hog for YM2000 #2
5' maximum and you can bog down with that in heavy stuff. Using it with common sense will work fine.
Thanks Winston, I found a decent 4ft, but I do have about 2 acres of HEAVY stuff that I need to get cut
/ Bush Hog for YM2000 #4
For heavy cutting the 4' would be a better fit.
/ Bush Hog for YM2000 #6
I probably could run a 6 footer. But because most times I cut thick stuff. I run a 5 footer. I can bog my engine down with the 5 footer
/ Bush Hog for YM2000 #7
I have a ym2000 I also own a 4 and 5 ft Bush hog. In very thick stuff you can overload a 5 footer in 6th gear and have to go to 5th. With the 4 footer you can run 7th gear all day in all but the thickest stuff and then you can almost run 6th gear in very thick stuff with the 4ft. I leave the 5 connected now and if it gets thick I just only take a 4ft bite.
/ Bush Hog for YM2000 #9
Thanx guys
Choosing a bush hog for a ym2000 involves more than how big of hog the tractor will run. The engine might be able to run a five or six footer but the physical size and weight of a five or six overloads the tractor. Even with a five footer you will need weight to keep the front end down in certain situations. A four footer is a much better compromise and when the day is done, you will have cut just about as much.
I decided to go with the 4 footer, it seems like all around, the smartest, best, as well as, the most practical decision for me at this point. thanks for all of the input guys.
/ Bush Hog for YM2000 #11
I agree with a 4'. I use one on my 2000 and it works very good. The Tractor has no problem and easily handles it.
/ Bush Hog for YM2000 #12
there are light duty 5ft ers that are not that heavy.
/ Bush Hog for YM2000 #13
I've been using a pretty heavy 5' unit with my YM240D (same as the YM2000; only domestic rather than import I believe). My impression is the unit I've got is a bit heavy. I like the size because the BH covers the tractor's tracks. I've got less than 2 hours using it to clean up some trash in a pasture that doesn't have much in the way of grass at the moment- it's mostly multi-flora rose, some golden rod, or some small Hawthorne trees. The machine bogs down a bit on any incline, but I'm usually running in 6th gear since the grass is so light. It handles it okay, but I think I'd be more relaxed with a lighter or small BH.
/ Bush Hog for YM2000 #14
Yea Wolly that is a HEAVY 5fter you have. I can mow almost the thickest stuff in 6th gear and in light grass can mow in 7th even up slight slopes. But also consider you have a loader thats hundreds of pounds more weight than i have on my ym2000 (and yea your right, paint, internal over run clutch and the direction the throttle goes is the only difference)
/ Bush Hog for YM2000 #15
You're right about mine being heavy. I'm afraid what would happen to the front end if I DIDN'T have the loader!
I think a lighter 5' or heavy-ish 4' would be a good fit. I still don't have mine setup correctly. I did move the lift-pins on the front down a couple inches to the lowest provided mounting holes, but I think the rear of the BH is still too low. Since it's not my BH I don't want to do a lot of re-configuring. It does okay, I just need to be attentive and go slower than I would if I were running the 45HP machine that normally runs this BH. But that's no surprise.
/ Bush Hog for YM2000 #16
I know that this does not really help you but....
I just wanted to show the pic of my bushhog. It is a very similar one to the one that woolyAcres has. It has no problem lifting it and the amount depends on the length of the top link.
One thing that I found interesting is the amount of additional weight the YM2001 has over the YM2000. According to the specs, it could be as much as 400-500 pounds. I shut off the engine with the bushhog raised in the pic and stood on top of the mower to see if it would raise the front end. I weigh a little over 200 pounds and I could stand on the back edge of the bushhog and the front wheels did not raise. I had to bounce a bit to get them to raise. I found this interesting. I guess this is why I have never had trouble steering with the bushhog in place.
It might help somebody.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2011 Renegade Mobile Command Center Trailer (A61573)
2011 Renegade...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
