Bush Hog for YM2000
/ Bush Hog for YM2000 #2
5' maximum and you can bog down with that in heavy stuff. Using it with common sense will work fine.
Thanks Winston, I found a decent 4ft, but I do have about 2 acres of HEAVY stuff that I need to get cut
/ Bush Hog for YM2000 #4
For heavy cutting the 4' would be a better fit.
/ Bush Hog for YM2000 #6
I probably could run a 6 footer. But because most times I cut thick stuff. I run a 5 footer. I can bog my engine down with the 5 footer
/ Bush Hog for YM2000 #7
I have a ym2000 I also own a 4 and 5 ft Bush hog. In very thick stuff you can overload a 5 footer in 6th gear and have to go to 5th. With the 4 footer you can run 7th gear all day in all but the thickest stuff and then you can almost run 6th gear in very thick stuff with the 4ft. I leave the 5 connected now and if it gets thick I just only take a 4ft bite.
/ Bush Hog for YM2000 #9
Thanx guys
Choosing a bush hog for a ym2000 involves more than how big of hog the tractor will run. The engine might be able to run a five or six footer but the physical size and weight of a five or six overloads the tractor. Even with a five footer you will need weight to keep the front end down in certain situations. A four footer is a much better compromise and when the day is done, you will have cut just about as much.
I decided to go with the 4 footer, it seems like all around, the smartest, best, as well as, the most practical decision for me at this point. thanks for all of the input guys.
/ Bush Hog for YM2000 #11
I agree with a 4'. I use one on my 2000 and it works very good. The Tractor has no problem and easily handles it.
/ Bush Hog for YM2000 #12
there are light duty 5ft ers that are not that heavy.
/ Bush Hog for YM2000 #13
I've been using a pretty heavy 5' unit with my YM240D (same as the YM2000; only domestic rather than import I believe). My impression is the unit I've got is a bit heavy. I like the size because the BH covers the tractor's tracks. I've got less than 2 hours using it to clean up some trash in a pasture that doesn't have much in the way of grass at the moment- it's mostly multi-flora rose, some golden rod, or some small Hawthorne trees. The machine bogs down a bit on any incline, but I'm usually running in 6th gear since the grass is so light. It handles it okay, but I think I'd be more relaxed with a lighter or small BH.
/ Bush Hog for YM2000 #14
Yea Wolly that is a HEAVY 5fter you have. I can mow almost the thickest stuff in 6th gear and in light grass can mow in 7th even up slight slopes. But also consider you have a loader thats hundreds of pounds more weight than i have on my ym2000 (and yea your right, paint, internal over run clutch and the direction the throttle goes is the only difference)
/ Bush Hog for YM2000 #15
You're right about mine being heavy. I'm afraid what would happen to the front end if I DIDN'T have the loader!
I think a lighter 5' or heavy-ish 4' would be a good fit. I still don't have mine setup correctly. I did move the lift-pins on the front down a couple inches to the lowest provided mounting holes, but I think the rear of the BH is still too low. Since it's not my BH I don't want to do a lot of re-configuring. It does okay, I just need to be attentive and go slower than I would if I were running the 45HP machine that normally runs this BH. But that's no surprise.
/ Bush Hog for YM2000 #16
I know that this does not really help you but....
I just wanted to show the pic of my bushhog. It is a very similar one to the one that woolyAcres has. It has no problem lifting it and the amount depends on the length of the top link.
One thing that I found interesting is the amount of additional weight the YM2001 has over the YM2000. According to the specs, it could be as much as 400-500 pounds. I shut off the engine with the bushhog raised in the pic and stood on top of the mower to see if it would raise the front end. I weigh a little over 200 pounds and I could stand on the back edge of the bushhog and the front wheels did not raise. I had to bounce a bit to get them to raise. I found this interesting. I guess this is why I have never had trouble steering with the bushhog in place.
It might help somebody.
TAYLOR Y-754-33 ISOFTECH INDUSTRIAL ICECREAM MAKER (A64281)
TAYLOR Y-754-33...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
CHAIN LINK FENCE (A64281)
CHAIN LINK FENCE...
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2023 Caterpillar...
