Adding/Upgrading Headlights on YM2000
/ Adding/Upgrading Headlights on YM2000 #1
Jamester
Memphis, Tennessee
Yanmar YM2000
Is it possible for me to add or upgrade headlamps on the YM2000, without having to "modify" the factory wiring scheme of things??
If not...what modifications must I make??
/ Adding/Upgrading Headlights on YM2000 #2
Hi Jamester- I can't help you but I'll be watching this thread. My YM240D will be doing a lot of snow work this winter and much of it will be during dark hours. I'd like to upgrade mine to LEDs for brightness. If you find something that fits I hope you'll keep this thread updated.
Absolutely, The HID/LED upgrade is the same mod that I was hoping to do to my ym2000 as well...
/ Adding/Upgrading Headlights on YM2000 #4
I have started a couple of times to look for a solution that fits in the hole that we have for the headlights and be led so as not to add any additional load to the 15 amps my "alternator" makes. I could not find anything that would fit that space....but I am sure there is something out there. However, I did what many others have and installed 4 led work lamps. Two that face forward mounted on the ROPS and another facing backwards in the center of the ROPS and the 4th on the fender pointing backwards.
/ Adding/Upgrading Headlights on YM2000 #5
I read , i think on here somewhere where someone used like H3 bulbs or something maybe a different buld? they used like a coke can and cut a circle out of it with a mounting hole and then trimmed the plactic lense back to accept that then maybe mounted a flange to accept the buld or something? I really and not sure..i saw it on here somewhere i beleive? That was years ago so its burried somewhere on here
/ Adding/Upgrading Headlights on YM2000 #6
What I recall reading was that the bulb/reflector components that Yanmar used were shared only with a Yamaha snowmobile of the same or earlier era - or something like that.
So there isn't a drop-in modern LED replacement system on the market. Therefor you need to remove the Yanmar stuff to make room for some similar replacement.
For me ... I would keep it simple and just go with LED lights added to the ROPS.
/ Adding/Upgrading Headlights on YM2000 #7
i too would just add LEDs as there bright and simple auxillary install and require little power.
maybe a nice LED light bar, or something to that extent????
/ Adding/Upgrading Headlights on YM2000 #9
I haven't seen many lighting projects in this Yanmar forum but there are lots in some other forums. Review a few pages of the main 'today's posts' list. Or maybe search the whole site on 'LED'.
/ Adding/Upgrading Headlights on YM2000 #10
I would think that:
  • Tractor has ample power to light LED's
  • High/Low function might be lost, or not easily maintained. If you could find four small light bars I would think you could achieve a low beam/high beam with your existing wiring.
  • You could get close (little big/little small) to the factory size of lights and will have to create/fabricate a way to mount the lights. Aim for the small side if the idea of inset lights troubles you.
  • Dispite the fact that LED's should not be damaged from vibration any mounting of helights should consider some kind of dampining so the whole things dosnt rattle apart
I'm thinking on doing this to my tractor some day. As of now I have a light on the back which serves me well enough. Front headlights are there and functional, but I need the most light while blowing snow with the 3 PT snowblower...
Seems as if the previous owner removed the ROPS from this YM2000 before I wound up with it...
that kinda sux, because that would have been the ideal place to install an LED light bar, or add additional lighting...oh well
/ Adding/Upgrading Headlights on YM2000 #12
Yea those LED light bars that are popular now are rediculously bright. THose things have exploded in populairity and price. I guess cause chinese ones can be had cheap?
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
