C140 track drive
/ C140 track drive #1
tonyoz
Queensland & Far South Coast NSW Australia
Rayco
I've just had to repair the second track drive. Now these dam things have the motor integrated into the planetary hub so the complete unit has to be removed for repair. What lets go is the spline on the end of the rotating group sending debris through the hydraulic system. Don't you just love well though out manufacturing, kinda like buying a car designed and made by someone who can't drive and rides a push bike.
/ C140 track drive #2
How many hours are you up to on it?
/ C140 track drive #4
I had a 140 . It had low hours . Bolts in the final drive came out and wound up all the lines . Had never ending hydraulic problems . My advice : Repair , make it look good , get rid of it as fast as possible . I have a Valtra and a Fendt with mulchers now . They are trouble free and oh so comfortable .
/ C140 track drive #5
tony, sorry you are having problems. if you can justify it with busy, look at the new CAT mulcher platform. It's specs look good and I know it was tested for awhile and has been updated quite a bit from the old style. I imagine a big CAT will have good support worldwide.
/ C140 track drive #6
You are supposed to re torque and check on those bolts. It's in the operators manual.
/ C140 track drive #7
The bolts never fell out ,they broke . The operator was working in wet snow . at the tracks were slacked off all they could . Snow and chips built up and the bolts let go . Don’t worry about service the machine was regularly checked .
/ C140 track drive #9
It was the right track . We had a hard time to get lines and never did get some adaptors . Had to retap the case drain line , i believe . I was happy to see it go . I have had way better luck with the tractors with PTO mulchers and forestry tillers . I do have a 470 hydro axe and really like it though . I just bought a GT25 . It is different to run but has the same basic drive as the axe . Plasance it trying to get me to import and sell for them . They have some nice grinders.
