5500 HSU rebuild?
   / 5500 HSU rebuild? #1
ricky1
Southeast Ohio
Mahindra 5500,8n Ford
found info
   / 5500 HSU rebuild? #2
Pls share info with me. My 4500 4wd HSU is spewing fluid.
Thank you
   / 5500 HSU rebuild? #3
45004wd Mahindra, I am having the same problem with my 4500 4 wd, what did you find out? Any help will be appreciated.
   / 5500 HSU rebuild? #4
No problem.... I had a friend, mechanic on side, take it out and replace the gaskets and O-rings. He bought them here in Dothan at local hydraulic shop for $23....not 90 like dealer wanted. Also, dealer wanted 250 just to rebuild it....with no labor included.
THE KEY to getting it out for repair is having the angled head combination wrenches....if you have them OR can find some cheap ones to torch/bend you can remove/reinistall it yourself probably.
He charged $222 to take it out, "rebuild it", and re-install it....like new now....but, it did bow the seals in the front hydraulic stering ram so be ready for that possible.....
Best of luch to you with it.
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2013 Ford E-350 Passenger Van (A49461)
2013 Ford E-350...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
1996 FRUEHAUF 48X96 T/A FLATBED (A50854)
1996 FRUEHAUF...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
