I found this on another site the people were complaining about the plastic cam gear being the problem, not the camshaft. It may help you in budget planning and provide a listing of the parts needed.
PARTS FOUND IN THE KIT AS RECEIVED from ebay seller partsforyourmachine seller ($380).
1. Crank Oil Seal 92049-2112 (also in the bag was an oval o-ring and a nylon T)
2. Intake gasket 11060-2088 - qty 1
3. Intake gasket 11060-2087 - qty 1
4. Carb gasket 11061- 2106 - qty 1
5. Exhaust gasket 11060-2079 - qty 2
6. Rocker cover gasket for black composite covers 11061-2182 - qty 2
7. Head gasket 11004-2107 - qty 2
8. Water pump gasket 11060-2450 - qty 1
9. Water pump COVER gasket 11060-2451 - qty 1
10. Governor Gear assembly 49110-2073 - qty 1
11. Push rods 13116-2057 - qty 4
12. Crankcase gasket 11060-2449 - qty 1
13. Pivot arm 39003-2064 - qty 1
14. Valve springs 47078-2082 - qty 4
15. Tappets 12032-2064 - qty 4
16. Oil filter 49065-7010 - qty 1
17. Water pump 49044-2066 - qty 1
Additional parts purchased to finish the engine rebuild:
1. Valve keepers (Repair clinic ) at $.70 each Qty 7 -- $4.90. I lost one so I bought some spares.
2. Exhaust manifold studs (Repair clinic) at $.70 each – qty 4 -- $2.80. The threaded studs came out of the cylinder head on 3 of the 4 studs. New ones were in order.
3. Exhaust manifold nuts (Repair Clinic) at $1.20 each - qty 4 -- $4.80
4. Thermo Switch (Repair clinic) at $24.50 qty 1. The thermo switch reads engine temp and sends a signal to the red light on the dash warning you of an over temp.
5. Coolant Reservoir Tank (Repair clinic) at $14.50 qty 1. The original somehow ended up with a small hole in the side near the top. Silicone RTV plugged the hole for the last 2 years. Time for new one.
6. Kawasaki spark plugs (Repair Clinic) at $2.70
ea. Qty 2 -- $5.40
7. Thermostat Manufacturer #49054-2056 (Repair Clinic) Qty 1 -- $20.80. I wanted everything new in the cooling system.
8. T-Stat gasket (Repair Clinic) qty 1 $1.70
