What do you keep in your tractor toolbox?
/ What do you keep in your tractor toolbox? #1
ThatServerGuy
Member
Oxford,Ga
LS XR4145H
spare lynch pins, channel locks, hammer, duct tape.. Trying to think of other emergency go to's...
/ What do you keep in your tractor toolbox? #2
Apparently, every single nut, bolt, & pin I've picked up over the last 20 years. :D Plus a few wrenches and pliers.
/ What do you keep in your tractor toolbox? #3
I keep a chainsaw scrench in there (also matches nuts/bolts on my chipper), spare pins of all types, couple hydraulic fittings, a can of fluid film lube, and a couple common wrench sizes.
/ What do you keep in your tractor toolbox? #4
BFH, screwdriver, pliers, small pry bar and pins.
/ What do you keep in your tractor toolbox? #5
Big and small cresent wrench Pin punch screw driver(5way)hammer spare pins and shear bolts. Better yet what do you keep in the cooler!!:)
/ What do you keep in your tractor toolbox? #6
Usual tools. pins. some chain**, spare pins for 3 point arm connections and perhaps the handiest (for me) some (about 1/8" aluminum wire*)
I also have a small hatchet and a length of rope.
**Chain has pulled many a car out of trouble
* The aluminum wire is used to safety my 3 point turnbuckles as well as any lose items.
/ What do you keep in your tractor toolbox? #7
Several shear bolts for the bushhog, a couple large screwdrivers, various size wrenches from 3/4 to 1-1/16, vise grip pliars, normal pliars, and a whole lot of dust!
/ What do you keep in your tractor toolbox? #8
I haven't rigged a toolbox on my tractor yet but when I do its gonna have a pair of gloves and a flashlight it it.
/ What do you keep in your tractor toolbox? #9
I'd like to add a toolbox to my tractor, where is the most common spot to mount one?
/ What do you keep in your tractor toolbox? #11
Shear pins, crescent wrench, hammer, pliers and ear plugs and ear muffs. I can't believe how loud the new L2501 is. Might as well have a straight pipe off the manifold :)
/ What do you keep in your tractor toolbox? #12
Maybe the loader frame will work since I have a cab.
